heater problem
salvatorejrm
I am having a problem with my heater. It fires up when I turn it on but then kicks off before it reaches temperature then it try for fire up again but no fire then kicks off and then has to be reset, I'm not sure why it doesn't get spark after the initial start. It's a 1995 Gulfstream seahawk. Thanks
4 REPLIES 4
Eng208
Mine did something similar and I found a huge dirt dauber nest on the burner. Cleaned it and it works great. I have a screen over the exhaust so I don't know how they got in the tube.
97 Dodge 2500 Ext Cab 4X4 CTD with Goerend Transmission mod.(GVWR 8800lbs, or 4000 Kg)
95 Four Winds Fifth Wheel
99 Toyota Fourrunner V6
donn0128
Sail switch is as the name implies, has a sail attached to it that senses air movement and shuts the gas flow off if it does not sense air flow.
salvatorejrm
Thank you Don. I don't have a thermocoupler. But what is a sail switch?
Thank you
donn0128
Sail switch or thermalcouple failure.
