Help with furnace
tbax46
Need to know if any of you might take a guess on my furnace. It comes on for about 30 seconds, then goes off like it threw a breaker or something. It has propane. Not sure
what to look for. The fuse is okay or it wouldn't come on in the first place.
All suggestions appreciated.
Reflection 337
Silverado 3509HD
USN & 'Nam Vet
9 REPLIES 9
TXiceman
More than likely it is a voltage problem at the unit. Check for proper voltage at the furnace with the fan running. If the sail switch does not make, the ignitors and gas valve will not fire.
Ken
Amateur Radio Operator.
2023 Cougar 22MLS, toted with a 2022, F150, 3.5L EcoBoost, Crewcab, Max Tow, FORMER Full Time RVer. Travel with a standard schnauzer and a Timneh African Gray parrot
0rion
kjchipmunk wrote:
I had something similar to this when my batteries were below the required voltage to run the heater. It would try to start the heater, run the fans for a bit then shut off. New batteries fixed the problem.
yep...that's because the fans weren't running fast enough to close the sail switch.
It could be an ignitor but he would hear them firing and it would cycle longer trying to keep firing the ignitors. If that sail switch doesn't close you get no ignition.
kjchipmunk
2006 Ford F250, 6.0 Diesel,
2012 Forest River Cardinal 3675
WeBeFulltimers
Could also be bad or misaligned ignitor.
2012 Ford F-350 PSD SRW ** CURT Q24 ** 2018.5 MONTANA 3791RD
0rion
have had this happen on 2 furnaces I've owned....both times it was the sail switch. Just replaced the sail switch on my current furnace this fall due to this. It's an easy job and part is about $10. The hi limit switch is right on the front of the furnace and again.....$10 part if you wanted to try that first but I'm betting sail switch.
hilke40
My Suburban furnace, had exactly same problem, was high limit switch, on front behind panel. $8.50 for part. RV repairman said to tap on it and sometimes they would work. Mine did. Two screws and two clips on wires to replace.
kennethwooster
Ours went out last year and required a new board.
kenneth wooster- retired farmer. Biblical History Teacher in public HS, and substitute teacher.
wife Diana-adult probation officer, now retired.
31KSLS Full Body paint Cameo
Ford F350 2014 DRW 4X4 King Ranch.
20K B&W Puck mount hitch
Dakota98
This may help
Trouble shooting Furnace
I'm an expert in only one field....I believe it's somewhere in Kansas.
2000 / 22' SKYLINE NOMAD LITE
1998 DODGE DAKOTA / 5.2L= 8mpg.
2006 POLARIS ATV
1500/1200 Watt Champion generator
Yada Wireless Back Up Camera
1998 Dyna Wide Glide
USMC 68-74
donn0128
Propane regulator, hi temp limit switch would be my first two guesses.
