Hot water heater problem
hawkpat
Took 5er out for first time this year. Turned electric on for hot water. All was good.
This morning no hot water, light on switch was dark. Tried gas and that light also failed to come on. What do you think happened?
Checked fuses in fuse box and switched them all off and back on. Still no change.
Thanks for any help.
10 REPLIES 10
mudmaker
Don't forget to label that fuse!
Glen and Loretta
Marc, Jake, Kirsten and fur kids Dexter and Bernie
2017 KZ Venom 4114TK Toy Hauler
2015 GMC Acadia
15 Silverado 3500 SRW quad 6.6 Duramax
11 Silverado 3500 SRW quad 6.6 Duramax
DavinD
Now, why did the fuse blow?
2018 Coachman Chaparral 381RD
TV - 2013 Ford F350 Diesel SRW 4x4 Short Bed
enblethen
Thanks for the update!
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
hawkpat
It was a fifteen amp fuse. Had to check them one by one as there were no markings. Replaced it and both electric and gas work now. Thanks for the replies. Never had one of the 15 amp fuses blow before.
golf_bears
If you have a meter remove the switch inside the RV and check if there is any power coming to the switch. Let us know what you find out and we'll go from there.
enblethen
Propane needs to have 12 volts to operate. could be fuse, ECO or thermostat open.
Looked at drawings for 120 volt element. It appears that Suburban does not link the two systems together, or at least on drawings I looked at.
120 volt AC issue could be lack of shore power to the circuit. What type of service do you have in the rig, 30 or 50 amp? Are you using an adapter to connect to shore power?
Bud
USAF Retired
Pace Arrow
hawkpat
It's a suburban water heater.
Red light does not come on inside camper for electric or gas.
Had plenty of hot water last night. Woke up this morning switch light off. And no hot water.
Have reset all circuit breakers. There are a bunch of auto style 15 amp push in fuses above breakers. Have not checked them. None marked as water heater.
OpenRangePullen
If the water was already hot, it wouldn't need to be heated.
2013 OpenRange Roamer 395bhs
2022 F350srw Limited, tower
2021 F150 Platinum Hybrid, daily
2002 Accord V6/5spd, project
2014 Kawasaki Concours
enblethen
Lost 12 volt control.
Switched fuses? You should test the fuses using a meter or test lamp.
Make and model of water heater?
Bud
USAF Retired
Pace Arrow
golf_bears
What brand hot water heater? Only guessing here but not knowing the bran, no hot water using either electric or gas may be the circuit board.
