how close to front of 5th wheel hitch
jepalmer
can you place a cover or a tool box; i.e how much clearance does the hitch need?
Thanks
12 REPLIES 12
Dandy_Dan
If you are looking for a tonneau cover, I have the Extang Tri-Fecta tri fold cover and have had no problems. I also had an across the bed tool box that on most occasions was not a problem either being able to turn fairly sharp. This is all if you have a long bed. Good Luck.
dan218b@tds.net
Dan and Lori Branson
Anna 1 and Lily( The new one)
Sarah-7/16 and Beau at the Rainbow bridge
2015 Ford SD350 Crew Cab Power Stroke
2009 Open Range 337RLS
Old Fella Rally Member
RV.Net Ohio Rally Member
Beaker
I went with a Transfer Flow compo tool box and aux fuel tank. it sits flush with the bed and has lots of room between it and the hitch
I've had one of those for a couple of years. The aux fuel tank is the best accessory I've had.
2008 Silverado 2500HD Duramax
2010 Cruiser 26RK
lillyputz
I went with a Transfer Flow compo tool box and aux fuel tank. it sits flush with the bed and has lots of room between it and the hitch.
Lillyputz
Lillyputz
Two beagles. Lilly & Zuri
Reelay
RCMAN46 wrote:
ChopperBill wrote:
Carry this in my long box. Leaves me plenty of room for hauling my other stuff.
Kobalt 69-in x 12-in x 13-in Silver Aluminum Full-Size Truck Tool Box
I have the same basic tool box except under the Delta brand name. Probably made by the same china company. I have a Chevy short bed with a slider hitch. I have to be in a full jack knife to even come close to the tool box. At which time I am risking the rear window of the truck. If the slider is back no problem with the tool box or truck rear window.
X2
2003 Sandpiper 32 ft., 2006 Dodge dually Big Horn, 4X4, Cummins H.O., 6 speed, jake exhaust brake, Edge Tuner , turbo timer, AFE stage II intake, S.B. clutch, Toyo Open Country Tuff Duty tires, KF7/AQD-SAR139
RCMAN46
FlatBroke
Hitch Hiker
"08" 29.5 FKTG LS
Allworth
Sometimes called a "tool chest" instead of a "tool Box".
Formerly posting as "littleblackdog"
Martha, Allen, & Blackjack
2006 Chevy 3500 D/A LB SRW, RVND 7710
Previously: 2008 Titanium 30E35SA. Currently no trailer due to age & mobility problems. Very sad!
"Real Jeeps have round headlights"
Reelay
I had a great diamond plated tool box ,deep, and tall way too tall for my fifth wheel if I ever had to turn a sharp 90*. Sold it and bought one from O'Reillys, lower but also sits on the bed rails has a short profile lid the trailer misses it but several inches it is also diamond plated.
Cummins12V98
Highway Products make quality tool boxes that are flush to top of the bed.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
rhagfo
Thanks
This is a picture i took of cutting down my release handle, but you can see the below rail tool box I have. Can't remember for sure if it came from Home Depot or Loews.
BB_TX
You can get pretty close to the hitch. Unless you jackknife more than 90 degrees you only need a little over half the width of the pin box for clearance. Actually if you measure from the center of the pin to one of the front corners of the pin box, that is the distance you need to clear between the pin box and the toolbox or cover.
If you go with an above the bed tool box, then you would have to make sure the height of the tool box cleared the bottom of the front overhang of the trailer.
Dr_Quick
Look for a tool box that sets even or below truck bed rails, and you will not have a problem. The back of my below rain tool box comes to within about 4 inches of hitch supports.
If box sticks above the be rails, you will need 5 to 6 inches above the top to the bottom of overhang of trailer.
Dr Quick
