How to store between trips
camilllit
I keep my new 2019 Cedar Creek inside a garage. I have some questions and please help me. I have the coach plugged into shore power. I have the battery disconnect switch OFF.
1. Are both batteries being charged with battery switch OFF?
2. Should I extend all 6 leveling rams down? I now only have front 2 rams down.
3. It has a 120 volt residential refrigerator installed. The power inverter is showing a green light. It is obviously being powered with the battery disconnect switch in the OFF position. Is this normal?
4. Should I keep refrigerator/freezer doors closed? My older rv unit I had doors propped open between uses. We have not used the refrigerator freezer yet, just bought it 1 week ago.
Thanks very much!
6 REPLIES 6
ACZL
If level to begin with, then I could see just the front legs down. Here at the house all 6 are down and that's just because they have to, to make it level.
2017 F350 DRW XLT, CC, 4x4, 6.7
2018 Big Country 3560 SS
"The best part of RVing and Snowmobiling is spending time with family and friends"
"Catin' in the Winter"
Toolguy5
Splashers3 wrote:
Congrats on the new CC. Our 2019 CC has been home for about 3 weeks.
We have been told (by other CCRVOC members) to keep the back 4 rams up and only keep the front landing gear down.
Mike
What is the reason on keeping the back 4 rams up? If you were parked on a permanent site wouldn't you have it level all the time. ( all 6 legs down )
What am I not understanding?
Dan & Patty
Miss Pickles the Pomeranian Princess Rainbow Bridge 8/8/2023
2020 GMC 3500 Sierra Denali 6.6 Duramax / Allison tranny
2021 Jayco Eagle 319MLOK
BWRVK 3710 companion
Maddy the Pampered Pom @ Rainbow Bridge 12-3-2013
Splashers3
You need to keep the battery disconnect ON...otherwise the batteries will not charge. The OEM converter is not a 3 stage converter, so if you keep it hooked to power a lot, you need to periodically check the batteries' water level. I plan (within a few years) on replacing my OEM converter with a PD converter w/charge wizard.
I wish I could store mine under cover!!
When not in use, as others have said, keep doors cracked open, otherwise a musty smell will develop.
Enjoy your Cedar Creek and consider joining the Cedar Creek RV Owners Club.
Mike
2017 GMC 3500 Sierra Denali, C/C, D/A, DRW, w/40gal Aux tank, 18K B&W Patriot.
2019 Cedar Creek Hathaway, 34RL2 - w/Bells & Whistles and disc brakes
Traded 2009 Cedar Creek Silverback, GII, 32 WRL
Toolguy5
My inverter for fridge is powered up as soon as I plug shore power in. Even if inverter is turned off.
I leave mine plugged into shore power when at home with battery switch on. I turn fridge off and open doors. I can only leave the doors cracked open because I keep all slides closed.
Dan & Patty
old_guy
IF the refrigerator is not running , by all means open the doors.
Mandalay_Parr
I would leave battery switch ON to keep batteries charged.
Refer should run on shore power when plugged in.
Jerry Parr
Full-time
2005 Mandalay 40B
Cat C7 350, 4 Slides
Blue Ox, Brake Buddy
2004 CR-V Toad
jrparr@att.net
602-321-8141
K7OU - Amateur Radio
Kenwood Radios
ARRL, W5YI, & LARC VE
SKYWARN Weather Spotter
