If your TV is maxed out - How far can you drive?
JRS___B
My question is, if I buy a fiver that is as much, or maybe a little more, than what my TV is supposed to handle, can I still gently tow that fiver a short distance if the need arose?
What I have in mind in particular is if I buy a fiver that really calls for a dually if it is going to be taken out on the road, but I neither have a dually nor intend to to take the new fiver out on the road, could I, "in a pinch", drag that ne fiver for up to 200 miles from campground A to campground B with a SRW?
Or should I just hire someone to move it?
30 REPLIES 30
lillyputz
JRS & B wrote:
lillyputz - \
Running empty, 110 psi sounds like a hard ride and maybe even decreased traction on wet pavement.
What would you run them at when you are not towing?
They are M&S traction tires. I run 80psi unloaded. Besides the added load limit, with the higher plys and steel side walls ratings, you don't get any body roll, like with the standered LT tires. They also run cooler and get high tread milage.
Lillyputz
Lillyputz
Two beagles. Lilly & Zuri
JRS___B
As always, I continue to learn from this forum. Thanks for the input.
noteven
Before we bought a FW toy hauler I researched part numbers between my 06 SRW Dodge 3500 and 06 SLT dual rear wheel model. The frame, axle, wheel outer ends and springs & attachments are shared parts. The door sticker weight rating (lowest component) is the Rge E tire rating x 2 tires. I installed 19.5 wheels rated at 5000 lbs each and 19.5 tires giving me over 9000lbs rating for the pair.
I run 70psi minimum and inflate to load/inflation table pressures if the the weight exceeds what 70psi is called for.
Our 17,000lbs FW with some groceries and a part load of fresh water puts the rear axle right at the door sticker (not over) and the higher rated tires and wheels give me the spare tire/wheel capacity I want (20% - 30%).
Previously we have hauled our truck camper / enclosed trailer combination over 20,000 miles with the Rge E rear tires right on axle max without incident but this was winter travel with no temps over 75F.
I also pull other trailers as needed with this truck with combined weights up to 26,000lbs. I sometimes have to shift out of high gear when grades exceed 6% but then I guess that is why it has a "6 speed" trans...
Based on our experience I would not change a truck out to haul a 16,000lbs FW regionally - I would use the money for rv travel...
I_am_still_wayn
joebedford wrote:
If it's a 1-ton SRW: sure. If it's a half-ton: no
WHAT? WAIT!
What is the difference between slightly overloading a 11 ton SRW and slightly overloading a half ton?
Are you saying a 1 ton SRW could successfully and safely be slightly overloaded? Are you also saying that a half ton could not successfully and slightly be overloaded?
That makes no sense to me!
Dave_H_M
It would of been cosher (I think) to give some weights up front.
Salty_Dog
Weight ratings are all well and good but the person driving has much more impact on safety. If you are within all ratings, a person could still drive like a moron and put everyone around you in jeopardy. (I was out of popcorn...)
Wife, kids, somebody else's kids, dog, kitchen sink
Cleverly disguised as an adult.
larry_barnhart
Ok so the big trucks are running single tires, big deal the tires are probably at the same distance outside to outside when it was a dually rear setup and not where the inside dual tires would be. No magic anywhere just common sense a dual rear truck beats a single rear pickup for towing large fifthwheels.
chevman
chevman
2019 rockwood 34 ft fifth wheel sold
2005 3500 2wd duramax CC dually
prodigy
KSH 55 inbed fuel tank
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
FMCA # F479110
pronstar
Allworth wrote:
I'm sure I'll catch He== from the DRW fanatics for this, but THERE IS NO MAGIC IN DRW!!
Thousands of heavy trucks and trailers running Super Singles agree with you.
'07 Ram 5.9 QC/LB SRW
Full Carli Suspension
35" Toyo's | 4.56 | PacBrake
2009 Cyclone 3950 | B&W Turnover Ball & Companion | TrailAire | Duravis R250s
Me_Again
About 100 feet then the slide on coax adapters pull apart! I and thought about getting another length of coax and another barrel connector, however I can not see the 32 inch screen at 100 feet now! Chris
rhagfo
So just what are you thinking of pulling? An 07 SRW Ram 3500 should be able to do a somewhat large 5er without exceeding the axle and tire ratings.
How far are you looking at? I tow over GVWR but have close to 1,000# of RAWR to spare. I don't give it a second thought, steers like on rails.
Slownsy
That is the fist time I have heard of a set of duly tiers that dobbelt the load rating what are they.
Frank
2012 F250 XLT
4x4 Super Cab
8' Tray 6.2lt, 3.7 Diff.
skipnchar
I can't recall ever seeing a trailer that specified the number of wheels the tow vehicle needed to tow it. Every one I"ve ever seen (and I've seen a lot of them)indicate their weight and it's up to the user to have a tow vehicle that will handle that weight. I'd find the actual weight of your trailer and compare it to the specifications on your tow vehicle and make the decision based on ratings not wheels. All that being said, you can tow ANYTHING with ANYTHING that will tow it but you won't always be safe (you or anyone else on the road) and the tow vehicle won't always hold up well to the experience.
Good luck / Skip
2011 F-150 HD Ecoboost 3.5 V6. 2550 payload, 17,100 GCVWR -
2004 F-150 HD (Traded after 80,000 towing miles)
2007 Rockwood 8314SS 34' travel trailer
US Govt survey shows three out of four people make up 75% of the total population
Buckeye_Chuck
D!#&, I forgot to make the popcorn. Time out for a minute..OK?
2012 F250 Lariat 6.5ft. bed, 6.2L, 3:73 Gears
2013 Sabre 33CKTS-6
thomasmnile
I have an '05 Ram 3500 SRW, same tires, same RAWR as your truck. The question is how much of that 16000 lb. fifth wheel you propose to get is pin weight, keeping in mind that some of the RAWR is already used by the truck and whatever you may have in it. We had a fifth wheel that had a loaded pin weight of just under 2300 lbs. and I was bird watching with the headlights at night until I installed air springs to level the body. You could probably accomplish what you are suggesting, but I'm thinking the rear tires are gonna be screamin' and the front end of the truck is gonna be light on the steering.
