In search of my first fifth-wheel toy hauler.....
taws697
Hey guys, new to the forum. Looking to purchase my first fifth-wheel toy hauler. It's been a struggle to find one that meets all of my requirements. I'm looking for one that is 3/4ton towable, has a 12' garage, is 102" wide, and has an enclosed bathroom. That search has led me to the Nitro XLR 305VL5. It looks like I can pick a nicely loaded 2015 for about $42k. This floor plan was newly released for 2015, so unfortunately I haven't been able to get on feedback on how well it's liked. But, I'm curious if anyone has had any experience with XLR Nitro trailers? Quality? Any Issues? Thanks for your input.
Wes
07 LBZ Duramax CCSB: Prodigy 3, B&W Turnoverball, Companion Slider, 5000 Ultimate bags, CAI, 3" Downpipe, 5" Straightpipe, Transgo Jr....
10 REPLIES 10
lincster
taws697 wrote:
Everything your saying makes sense. Thanks for your reply. I've heard that they pin weight tends to not go up much on toy haulers because a decent amount of the weight your adding is at the rear of the trailer. Is there any truth to this?
Not at all.
My trailer has 2670lbs of pin weight totally empty.
I put 150 gallons of water in it, which are in front of my front axle (pin weight goes up)
I then put my 2800lb sand rail in the trailer, majority of which is behind the rear axle, my pin weight goes up to 3400lbs.
This is why I have a dually. Don't have to worry about this stuff.
2022 F350 PSD CC 4X4 Dually to pull 2006 LE3905
Lincsters Truck/Trailer
Lincsters Rail
azdryheat
With nothing in the garage, my pin weight is 21% of the total weight and I believe most toy haulers run about the same. Putting something in the garage will reduce the pin weight but not by much.
2013 Chevy 3500HD CC dually
2014 Voltage 3600 toy hauler
2019 RZR 1000XP TRE
lawrosa
One of the better non 5th wheel toy haulers... No need to worry about pin weight...WD hotch all the way and you get full size camper in 30 ft... Hey bring the kids or friends...
http://outback.keystonerv.com/#/floorplans
Or this one is new...
http://www.keystonerv.com/outback/
Mike L ... N.J.
2006 Silverado ext cab long bed. 3:42 rear. LM7 5.3 motor. 300 hp 350 ft lbs torgue @ 4000 rpms
2018 coachmen Catalina sbx 261bh
Sprink-Fitter
You are adding weight and that helps reduce pin weight, but if you are like us, there are times we don't bring the side X side, so it is added bumper weight for us.
2006 Coachman Adrenaline 228FB
2012 Can Am Commander XT 1000
taws697
Old-Biscuit
Mfg. 'magical' max tow rating is based on a 'base model with 150# driver and 20# of cargo'
A 12K trailer will get you a 'wet pin' of 2400#
With your 'upgrades' you will be able to handle a higher pin weight BUT that doesn't change what your truck GVWR is.
And don't discount total weight that gets added....folks have a tendency to pack. Guesstimating usually is way low..........little here, little there pretty soon 'loaded'
But with your statement.
I could personally care less about the legal side of it.
taws697
I just checked out the Cyclone 300c. It's a little big.....lol
taws697
Maybe you could school me a little on the GVWR side of things. I was under the impression that my truck was rated to tow about 14k. This model is just under 11k empty. I would never come close to putting 5000lbs in it. Maybe a max of 3k. I have upgraded the rear end to 3500SW specs. 3500 leaf packs, air bags, and ditched the factory aluminum rims which were only rated for 3042lbs a piece. The rims I installed are rated for 3400lbs and the tires for 3500lbs. I weighed the truck and it weighs 7100 full of fuel with the hitch in and 3 passengers. That leaves me with about 2100lbs for pin weight going by the factory specs on the sticker in the door.(Even though I think it will handle a little more with my upgrades). I could personally care less about the legal side of it. I'm more looking for my own piece of mind. Other than the weight issues, any reviews on the quality of the Nitros in general?
Old-Biscuit
GVWR of 16K or so.........and your 07 2500
I would continue looking.
You stated you wanted one 3/4 ton towable.
With your 07 that means GVWR of 12K or so to be within ratings/available 'actual' payload.
chiefneon
Howdy!
You might want to take,a look at the Cyclone 300c.
"Happy Trails"
Chiefneon
