May-23-2015 04:42 PM
May-24-2015 06:59 PM
Water-Bug wrote:
If you decide to go the spray foam insulation route, be very careful. It is engineered to be sprayed between substantial residential siding and wall-board. As it expands, it can seriously bow the interior and exterior walls of an RV.
May-24-2015 06:39 PM
May-24-2015 12:21 PM
erw1988 wrote:That would be the best bang for the buck park under a shade tree or buy a carport. Instead of a single large A/C I would use two units, one in the bedroom another in the living room and use fans to circulate the air. I have seen some rv parks in Texas that had a large carport over the site for a additional fee.
Yeah, we bought the unit with the intention of having no monthly payments (which we don't.) Can't really afford a new one. I'm honestly fine with having to park under a tree or canopy. We'll be in east Texas, where there are a lot of pines, so finding shade won't be an issue. I really dislike the heat, so that's just been the major thing; trying to keep cool in the trailer.
May-24-2015 12:06 PM
erw1988 wrote:
Damn, alright. Thanks for the reality check, y'all. Then that would bring me to another question: what's the best way to retain heat and cold inside the trailer? Winter living in Oregon (in the Portland area anyway) isn't too big of an issue for us. I'll just put a skirt around the thing and make sure any air leaks are plugged. But we're moving to Texas next year and want to be able to retain cool inside the trailer as much as possible. Is the best way to do this just to park under a tree or canopy, away from the sun for much of the day, and put tint on the windows, while running a window shaker? (We're going to have shore power in the summer and there is no AC installed in the trailer right now.)
May-24-2015 11:34 AM
May-23-2015 09:27 PM
rhagfo wrote:Whoops. I did one years ago to fix some water damage. Yup I forgot..you start at the bottom, not the top...scuse me..B.O. Plenty wrote:
What about adding furring strips to the inside to make the walls thicker and adding a layer of polystyrene foam. Or remove the siding, (easy job, just start at the top and work down. And add a layer of 1/4" to3/8" thick foam insulation board like they use under residential vinyl and metal siding. It won't offer a lot but it will seal up all the gaps. Just sayin...
B.O.
If removing Aluminum siding you start at the bottom and work up. Voice of experience!
May-23-2015 08:50 PM
B.O.
May-23-2015 07:42 PM
May-23-2015 07:34 PM
May-23-2015 06:21 PM
May-23-2015 06:15 PM
May-23-2015 06:12 PM
May-23-2015 05:56 PM
May-23-2015 05:51 PM
