Junk Yard Gas Tank for Aux Fuel
DougE
I'm considering pulling a small gas tank from a junk yard vehicle to use as an auxiliary fuel tank. I would use it to fuel my Yamaha generator and scooter. It seems like it would be simple to fire up the in-tank fuel pump and even add a gas gauge. Has this been done by anyone?
Currently Between RVs
11 REPLIES 11
Bedlam
Moderator
Moderator
Check eBay out for aluminum dune buggy or hot rod fuel tanks. 10-15 gallon models frequently are for sale for under $150.
vic46
dedmiston wrote:
vic46 wrote:
I do not know but, it is a real safe bet that there is a whole hockey sock full of rules and regulations regarding this proposal. Slip fuel tanks, for the box of of a pick up, require Canadian DOT certification so I am told. They are usually welded steel.
The appearance, as noted above, may not be the only concern.
Vic
Canadin what? Huh?
The OP is in Texas. What am I missing?
JUST AN EXAMPLE OF WHAT THE OP MAY ENCOUNTER!!!!!!!!!!!!!!!!!!!!!!!!!
[COLOR=]Never argue with an idiot. You will be dragged down to their level and then beaten with experience.
coolbreeze01
Some people use a 55gal drum. Hand pump or electric. Beats 5gal cans.
2014 Sandsport 26FBSL
DougE
My signature shows that I'm using a Chevy van now but I intend to trade in for a pickup this winter so I'm not carrying the generator and gas tank in an unventilated space. Another, although more expensive, alternative to junk yard tanks is an aftermarket, universal fuel tank sourced from the hot rod industry. A 13 gallon tank would be about 100# when full.
allcool
IMO, correct mounting the tank is what will make this idea workable and semi safe.
Problem is, mounting a 200#(?)plus, full oem gas tank in your PU bed could be a challenge. Most of the oem tanks are weird shapes and do not have a perfectly flat bottom, making mounting the tank sturdily a real challenge.
But with some good planning, sure it could be done.
jmo
2007 WW FSW3200
RZRS k&t Turbo
2 LT500
1 Lt500 hybrid
F350 CC 6.7PS Platinum
texasclarks
Where are you going to mount the auxiliary fuel tank? Trailer or van?
Posts are for entertainment purposes only and should not be construed as endorsement or recommendations. YMMV!
Steven & Stacie, plus 2 ('02 & '07)
'04 Suburban 2500, Quad Seats, 8.1L, 3.73
'09 Rockwood 8313SS
Texas not just a State, but a State of mind!
dedmiston
Moderator
Moderator
Vic
Canadin what? Huh?
2014 RAM 3500 Diesel 4x4 Dually long bed. B&W RVK3600 hitch โ€ข 2015 Crossroads Elevation Homestead Toy Hauler ("The Taj Mahauler") โ€ข <\br >Toys:
  • 18 Can Am Maverick x3
  • 05 Yamaha WR450
  • 07 Honda CRF250X
  • 05 Honda CRF230
  • 06 Honda CRF230
vic46
Vic
DougE
If it's in the back of a pickup with a tonneau cover its looks don't matter too much. The cheap red plastic tanks they sell for this purpose don't impress me either. I'd kind of like to find a boxy black polyethylene tank for this purpose. It looks like the standard fuel pumps put out about 40 gph so it would take about 3 minutes to fill up my scooter.
Gonzo42
Better get the tank boiled out, checked for leaks, and then add sta-bil or some other gasoline preservative.
MOTHER SHIP Winnebago View 24H (2007 Dodge Sprinter 3500 Chassis, 2008 Body)3.0 L M-B Diesel V6 bought used with 24K miles. Toad: ROCKY the Flying Squirrel.
fj12ryder
I'm sure it could be done, but it sure would look really low rent. ๐Ÿ™‚
Howard and Peggy
"Don't Panic"
