Landing gear ? 2009 Montana 3665RE
Brad_NSW
Both my landing gear and rear stabilizers quit working using the buttons in the little door on the front drivers side. However, they both work using the key fob remote.
I checked both fuses in the front storage compartment. Is there another fuse that controls both I don't know about? Anything else I should be looking at to troubleshoot?
Thanks in advance for any advice.
USN Ret. 03Ram3500, 5.9CTD, 5spd, SRW, ATS filter, S&B Intake, IssPro (Pyro, Boost, Fuel, Trans & R Dif) SMARTY SR, Prodigy Controller, AirDog 100. 09Montana 3665RE 5er, 6 TST Tire monitors. Pakbrake Ex brake & airbags, 12' Baltik inflatable w/3.3HP OBM
5 REPLIES 5
stevediaz
Hello
You can check below steps -
Check for additional fuses near the control panel or battery.
Inspect the wiring between the buttons and control unit for any loose or damaged connections.
Test the switches with a multimeter to ensure they're functioning correctly.
Ensure all connections to the control module are secure and inspect it for damage.
Look for any settings or switches that toggle between manual and remote operation in your manual.
Hope it helps !
Thank you๐Ÿ™‚
Helpful tips but this thread is 11 years old and the OP hasn't been on here in years. This thread got bumped from a SPAM post.
Carl_n_Susan
Nomad II
Nomad II
This is a known problem with the Remote Control system on Montanas (and others). There is a "failsafe" circuit to keep the user from using the remote switches and the manual switches at the same time. The connections on the receiver in the front compartment only affect the landing gear and stabilizer switches. The failsafe will not provide a ground to the manual switches when the remote system is energized and will sometimes get "locked" in that position.
You can buy a new control unit for the remote system or you can circumvent the problem. To circumvent the problem, join the Montana Owners Club forum (free to join) at www.montanaowners.com and go to the link
http://www.montanaowners.com/forums/showthread.php?t=46515
This "trick" has worked for many Montana owners.
Temp Signature1
Second Line
Third line
Fourth Line
et2
If the FOB operates them I expect it isn't a fuse issue. Probably something in the switches or wiring. Can you pull them out and check the connections?
marksoldtowne
I think there is a problem with rear stabilizers. But can't tell you surely. If you are in California get a proper check of the fuses.
