Apr-29-2013 09:53 PM
Jul-05-2024 01:58 AM
Hello
You can check below steps -
Check for additional fuses near the control panel or battery.
Inspect the wiring between the buttons and control unit for any loose or damaged connections.
Test the switches with a multimeter to ensure they're functioning correctly.
Ensure all connections to the control module are secure and inspect it for damage.
Look for any settings or switches that toggle between manual and remote operation in your manual.
Hope it helps !
Thank you🙂
Jul-05-2024 05:56 AM
Helpful tips but this thread is 11 years old and the OP hasn't been on here in years. This thread got bumped from a SPAM post.
Jul-04-2024 02:46 PM
This is a known problem with the Remote Control system on Montanas (and others). There is a "failsafe" circuit to keep the user from using the remote switches and the manual switches at the same time. The connections on the receiver in the front compartment only affect the landing gear and stabilizer switches. The failsafe will not provide a ground to the manual switches when the remote system is energized and will sometimes get "locked" in that position.
You can buy a new control unit for the remote system or you can circumvent the problem. To circumvent the problem, join the Montana Owners Club forum (free to join) at www.montanaowners.com and go to the link
http://www.montanaowners.com/forums/showthread.php?t=46515
This "trick" has worked for many Montana owners.
Apr-30-2013 04:45 AM
Apr-30-2013 03:29 AM
