Landing Gear Problem
Charley67
My landing gear works (slowly) when cord is plugged into truck, but has stopped working on shore power. The 30 amp bus fuse near switch appears not to be blown. Any ideas?
15 REPLIES 15
GACamper
Glad to hear it was an easy fix.
2013 Montana 3800RE
RV FlexArmor sprayed RV roof..Big Improvement!
A/C, Color TV and a Microwave...Isn't Nature Great?
04.5 Dodge Ram 3500 Cummins 5.9L
Charley67
Found the problem, finally. There was a fuse hidden behind the battery box, well wrapped with tape. Replaced that and all is well.
Miles_Away
Every one is right when they say the landing gear runs off your battery. I would check you inverter (shore power charger). Could be it's not working and allowing your battery to drain. If it is working properly you should have plenty of juice to operate the landing gear, even with a weak battery.
M & M :C On the road again!
2007 GMC 3500-SRW-Duramax-longbed-4X4
2008 Keystone EVEREST 348R 5th wheel
2002 SUNDOWNER gooseneck horse trailer
GACamper
If you have a electrical tested trace the wires and see where the power stops. You could have a bad wire or bad or loose connection.
2013 Montana 3800RE
justafordguy
Must be a bad connection somewhere if it works with the truck plugged in but no other way.
2015 Heartland Gateway 3650BH
2017 F350 CCLB KR FX4
2005 F250 CC FX4
77 Bronco, 302,C4,PS,PB,A/C,33" KM2s,D44/Lock-Right,9"/Grizzly locker
Charley67
I put a new battery on it, but no cigar. The only fuse I have found is a 30 amp in line fuse behind the switch. It appears to be good. Any other ideas?
ACZL
Had same thing happen to me few years back. Battery was kaputzky.
2017 F350 DRW XLT, CC, 4x4, 6.7
2018 Big Country 3560 SS
"The best part of RVing and Snowmobiling is spending time with family and friends"
"Catin' in the Winter"
GACamper
Good point use Distilled Water if you have it
2013 Montana 3800RE
fj12ryder
Distilled water?
Howard and Peggy
"Don't Panic"
GACamper
If your able to disconnect the battery and put it on a slow charge. It may come back for you....Good Luck!
2013 Montana 3800RE
Charley67
Well, that all makes sense, and I appreciate the help. My battery is less than a year old. I took the tops of it, and it was about dry. I filled it up with water. It may be toast, but I'm hoping it will charge.
MFL
Nomad II
Nomad II
Charley67 wrote:
No, I haven't, but I will. Didn't know it depended on battery on shore power.
Heavy loads, landing gear, large slideouts, need a healthy battery, even when on shore power. A clue, in your case, plugging into truck helped a little. Just a small wire from truck plug to camper battery. If you used heavy jumper cables direct from truck battery, to camper battery, landing gear should work like normal.
Jerry
GACamper
Even when your plugged in to shore power your landing gear still pulls power from your battery. Check your battery I'm guessing your going to find that's it's bad. If you can get your hand on load tester that would be the best way to test the battery.
2013 Montana 3800RE
Charley67
