Led Bulbs
Bigmoss
Last fall I purchased a 2015 Jayco Eagle HT28 foot and want to change my regular bulbs to some softer Led bulbs. I find the ones in there now way too bright. I phoned the dealer to ask if there was a specific number led I should buy in order to not cause damage. They said they had no idea.
Searching the net there are a TON of bulbs to choose from. Does anyone know of the Jayco's use a specific model bulbs I can just order online ?
2016 Ford F-150 Screw Lariat Short Box
2015 Jayco Eagle HT 27.5 RLTS
Reese 30051 Hitch with Revolutionary Pin
8 REPLIES 8
Greene728
Mel B. wrote:
I took the #'s off my stock bulbs in our Montana and ordered the same # on amazon for 12 voltt LED lights I bought 30 leds for $36 work great and uses very litle power on our solar system.
Mel
Yep. It's not difficult. Op, pull the bulbs, get the number, then search that number for LED replacement. Amazon has a huge selection!
2011 Crossroads Cruiser 29BHS ( Traded )
2017 Grand Design 303RLS ( Sold )
Currently camperless ( Just taking a break )
2016 Chevy Silverado 2500 4x4 6.0 and 4:10’s
Me and the wife and our two daughters. Life's good!
Mel_B_
Mel
rexlion
Pull out one of your existing bulbs. The base is either wedge shaped (T10) or round bayonet (like a 1157, if memory serves). Order LEDs with the same type of base.
Any LED under 200 lumens should provide noticeably less light than your incandescents, I think. A typical 1157 incan is about 400 lumens.
2700K is yellowy light similar to incans, 3000-4000K is whiter but still has a bit of warmth. Anything higher color temp than 5000K starts to look sort of blue and harsh IMO.
If you insert an LED into the socket and it doesn't light up, usually you need to take it out, flip it over, and reinsert it. They tend to be more directional about their current flow than an incandescent.
Mike G.
Liberty is meaningless where the right to utter one's thoughts and opinions has ceased to exist. That, of all rights, is the dread of tyrants. --Frederick Douglass
photo: Yosemite Valley view from Taft Point
SanMarMor
Look on your current bulb for the bulb number, then search Amazon for that number LED. You will find a lot. I've switch some of mine as they go bad.
Mark
2007.5 Chevy 3500HD Crew DMax Dually 4x4 w/ Curt Q5 20K Hitch
2011 Sabre 31RETS-6 w/ TrailAir Pin
44 nights in 2013, 37 nights in 2014, 27 nights in 2015, 29 nights in 2016
34 nights in 2017, 27 in 2018
http://camping.morrises.com/
spud1957
Any bulb less than 3000K (Kelvin) will give you a more warmer colour. Similar to regular bulbs. The higher the |Kelvin, the cooler (blue) the light. The higher number also gives you the impression they are brighter. They aren't.
2018 F350 6.7 4x4 CCSB
2022 GD Reflection 337 RLS
2oldman
I like the flat wafer ones. They have the standard automotive plug on them.
Bigmoss
IdaD wrote:
Amazon has them. You can pick the brightness and color temperature you like.
Yes but are are the plugs standard ? Usually there is a number for the bulb so it fits the socket
IdaD
2015 Cummins Ram 4wd CC/SB
