Leveling 5th Wheel to TV
travel4fun
Our family has just purchased a new 5th wheel that we are excited about. My TV has a 4" lift and I had the RV dealership flip the axles and added (1) 4" spacer on each side of both axles to help level the trailer to match up to my TV. After connecting the trailer it looks that it is nose high and still not level.
Look at the pic in my profile to see my set up. I am curious if I still need to add taller spacers or if this looks ok. Currently I have 9" of clearance between the bed rails and the bottom of the trailer.
Thanks.
2016 Palomino Puma 253FSB
2012 Ram Longhorn 2500
15 REPLIES 15
N-Trouble
travel4fun wrote:
Thank you all for your comments and suggestions. I have created a list of items to do to try and fix this issue.
1. I will first raise the pin box two sets of holes and I hope this will put the trailer between 5" to 6" of bed clearance.
2. Look at a different tire setup running LT 16" radials on the trailer (the RV dealership welded the spacers to the axles so that will take quite a bit of work to remove them) or changing the tire size on the TV (its about due for new tires anyway).
3. If those two things don't work then I will look at adjusting the suspension on my truck.
Also, I will look at addressing the squat on the TV after I get the truck and trailer as level as I can get it. I have already began looking at different types/styles of air bags to install to reduce the squat on the TV.
Any more suggestions are appreciated.
Fix the squat of the truck first as that will affect everything else
2015 Attitude 28SAG w/slide
2012 GMC 2500HD SLT Duramax
B&W Turnover w/Andersen Ultimate 5er hitch
phillyg
I personally wouldn't like the FW riding as high as it appears in the photo. I'm assuming you don't want to change it again and want to leave the truck raised. Instead, and if you can, lower the hitch head a notch and raise the pin and you should still have 6-7" of clearance which is optimal, anyway.
--2005 Ford F350 Lariat Crewcab 6.0, 4x4, 3.73 rear
--2016 Montana 3711FL, 40'
--2014 Wildcat 327CK, 38' SOLD
travel4fun
N-Trouble
You really need to level your truck out too. Got the Cali-lean going on both the TV and trailer. Sure not many drivers in the other direction are liking your headlights
tvman44
It is a little hard to tell because of the angle of the picture, but does not look too bad. 🙂
Papa Bob
1* 2008 Brookside by Sunnybrook 32'
1* 2002 F250 Super Duty 7.3L PSD
Husky 16K hitch, Tekonsha P3,
Firestone Ride Rite Air Springs, Trailair Equa-Flex, Champion C46540
"A bad day camping is better than a good day at work!"
RustyJC
Lifted 4x4 trucks and 5th wheels generally don't play nice together. With the current crop of 4x4s, it's a challenge getting everything leveled out with sufficient bedrail clearance with a stock truck. Although the OP has apparently already made his choice to tow with a truck with a 4" lift, others might want to rethink this unless they're willing to make major changes to the 5th wheel suspension and/or chassis and accept the resulting compromises to make this work.
Rusty
2014.5 DRV Mobile Suites 38RSSA #6972
2016 Ram 3500 Dually Longhorn Crew Cab Long Bed, 4x4, 385/900 Cummins, Aisin AS69RC, 4.10, 39K+ GCWR, 30K+ trailer tow rating, 14K GVWR
B&W RVK3600
the_bear_II
Agree with others you should be able to adjust the hitch height to bring the nose down a little more and leave 6 plus inches of clearance for the bedrails.
My 5th wheel sits as high as yours and I've been towing it that way for over 20 years with no stability issues. Before I had the axles flipped the tail often dragged when going in and out of driveways or dips. No more dragging my ### since then.
rhagfo
Old-Biscuit wrote:
rhagfo wrote:
Greene728 wrote:
travel4fun wrote:
Our family has just purchased a new 5th wheel that we are excited about. My TV has a 4" and I had the dealership flip the axles and added (1) 4" spacer on each side of both axles to help level the trailer to match up to my TV. After connecting the trailer it looks that it is nose high and still not level.
Thanks.
Based on the pics and your description (9 inches of bed clearance) either raise the pinbox a notch or lower the fifth hitch down in the frame a notch.
On a side note, I would be terrified pulling that camper raised that high. Stability has got to suffer set up like that. You also have quite a bit of squat on the TV (which is a beautiful truck BTW). But bags would only amplify your nose high problem I know. Good luck to you, but that set up would drive me nuts. Lol!
:h :h :h
With a 1,128# pin I think it is more the photo angle than squat!!
It would be nice, if you could get a good side view on a near level surface.
That 1128# is 'dry' pin weight........probably closer to 1600# when 5vr is loaded which could be close to 'payload rating' depending on truck's trim level
5rv doesn't look level......looks nose high and with 9" bed rail clearance 5vr nose can be lowered via adjustments of pin box/hitch
Hard to tell with that off angle squished photo in sig about truck squat and/or 5vr nose high
As for the method used to lift 5vr........not a fan of using spacers.
Sq. Tube subframe welded to trailer frame with sq/tube cross bracing is a tried/true method.
Even at 1,600# way below the GRAWR, even a newer 2500 will not drop much without 1,600#. I carry about 2,200# and squat 1-1/2".
I agree with the tube sub-frame for anything over 2".
This has been a couple years in the getting this level.
Old-Biscuit
rhagfo wrote:
Thanks.
:h :h :h
mtofell1
The bottom line is lifted trucks and 5th wheels just don't play nicely together. It's simple physics.... keep lifting the 5th wheel, lower the truck or adjust the hitch and lose bedrail clearance.
rhagfo
Thanks.
:h :h :h
rhagfo
travel4fun wrote:
BobKrogstie wrote:
Does the FW have 16" tires?
No they are 15" tires on the trailer.
#1 Raise the pin box two sets of holes with put you between 5" to 6" of bed clearance.
#2 What type of spacers did the dealer add?? Get rid of the spacers and have a sub-frame built to do the final leveling.
#3 you could always take the the lift out of the TV. OK maybe half the lift! :B
travel4fun
Greene728
Thanks.
2011 Crossroads Cruiser 29BHS ( Traded )
2017 Grand Design 303RLS ( Sold )
Currently camperless ( Just taking a break )
2016 Chevy Silverado 2500 4x4 6.0 and 4:10’s
Me and the wife and our two daughters. Life's good!
