Lower skirt/panel damaged
pinkdogwood
We had an unfortunate encounter with a light pole surrounded by concrete while we were tailgating last fall. It damaged the left lower skirt/panel on our 5er. Ours is made out of a metal, or aluminum. Since our brand (Alpenlite)in no longer in business, any suggestions on getting this repair done?
6 REPLIES 6
geotex1
SH wrote:
If you are talking about the aluminum j-panel, All-Rite can make what you need. You will need to paint it!
Yup, but before the paint on aluminum you're going to need a proper prep and priming. You can go with zinc chromate after an Alumiprep wash - old school and works - or Alumiprep scrub the Alodine followed by an epoxy primer. Personally, I don't like the bargain basement prep a lot of painters do with an Alumiprep scrub (using Scotchbrite pad) and a "wash primer".
SH
2001 Alpenlite 35RK
2007.5 Chev LMM Duramax/Allison
BD Variable Vane Turbo Brake
TST 507
2010 FLHTC Electra Glide Classic Red Hot Sunglo ๐Ÿ™‚
Allworth
IconDirect specializes in formed ABS plastics, but they may be able to match what you have. Contact Jason.
Formerly posting as "littleblackdog"
Martha, Allen, & Blackjack
2006 Chevy 3500 D/A LB SRW, RVND 7710
Previously: 2008 Titanium 30E35SA. Currently no trailer due to age & mobility problems. Very sad!
"Real Jeeps have round headlights"
fishingbob61
Buddy-Gregg RV in Knoxville is a full repair RV dealer, they have a big repair shop just off campbel station rd
Bob and Sue
51 years camping
2005 Fleetwood Bounder DP
2004 Chevy. Tahoe
mabynack
I've used these folks twice and they did a pretty fair job making a replacement. It was a pretty straightforward job replacing it. The old screw holes didn't line up and I just drilled new ones.
Icon Direct
netjam
Any body shop should work.. I think the panel is just sheet aluminum. If it were me, I'd go to RVsforless. Tiny little place but they've done great work for me.
