โMar-05-2016 05:53 PM
โMar-06-2016 11:04 AM
โMar-06-2016 10:42 AM
โMar-06-2016 08:45 AM
โMar-06-2016 05:37 AM
โMar-06-2016 04:21 AM
Randu wrote:
LT tires are winners.
I think all tires in general benefit if you can minimize the scuffing. Repeatedly putting tires in high flex conditions could contribute to tread separation over time.
I make multiple backward/forward corrections to get into tight sites to keep flex to minimum.
Randu
โMar-06-2016 03:58 AM
โMar-06-2016 03:52 AM
Cdash wrote:
I run LT's and have for several years. I make near 90 degree turns quite often, since I seem to have great luck in camp sites and general navigation snafus. Neither tire, not suspension has failed me yet.
No offense, but it seems that there is a tenancy to over analyze when it comes to this. The way I look at it, the ST's I could find locally kept blowing up, no matter how diligent I was at checking pressure. I was done wasting money on them. I bought new wheels (trailer had 15's) and 4 LT tires and haven't had a single tire problem in 4 years. I believe that vehicle tires are built too much higher standards than trailer tires.
Do it, be done with it and forget it!
โMar-06-2016 03:42 AM
โMar-06-2016 03:39 AM
โMar-06-2016 03:29 AM
โMar-05-2016 09:11 PM
christopherglenn wrote:
Forget the sidewalls. All that matters as far as the suspension goes is how much thrust does it take to make the tire slide sideways. On ice and snow it takes almost nothing to slide the tire, on a hot summer day on clean cement it takes a lot. The only thing providing the thrust is the suspension. The sidewall flex is only an indication of how much material is in the tire's sidewall.
โMar-05-2016 08:52 PM
โMar-05-2016 07:42 PM
โMar-05-2016 06:57 PM
azdryheat wrote:That's how I feel about it also, with my triple axle toyhauler.
I've got LT's on my triple axle and they've been in some pretty tight, scuffing turns with good results. Your double axle shouldn't be any concern.
