microwave after market
buc1980
My microwave broke down and I need to install inside the cabinet another one .What you recomand.I heard that the store microwave can't be install inside cabinet(not air circulation)
2017 Ford F350 DRW,2005 Kountry Star 35ft,16750 lb weight on SAILUN tire,6 points LIPPERD Level-up.New Mor/ryde IS suspension install.Full body paint 2022.RV flex roof 2023
11 REPLIES 11
RoyB
I have ended up with two microwaves units for my OFF-ROAD POPUP setup... One is a pretty nice one with digital display and just sets on the cabinet top to be used. when in travel mode it has to to moved down to the floor area so i can lower my roof down for travel.
My big 5th wheel trailer has the Microwave/oven combo which I never figured out how to cook with it using the oven part of it...
When camping off grid with my off-road POPUP trailer I have a much smaller manual knob type microwave. this draws minimum power and is mainly used to just warm up things. It will cook up a TV diner as well... This is one of those white faced manual knob microwaves with spring timer on it (WALMART)...
google image
When camping off grid you need to use things that doesn't draw much from the battery bank or small generator...
Roy Ken
Roy - Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
buc1980
Thank you all for all the feedback.
IdaD
Amazon sells several rv sized microwaves with the flange you can use to secure it into the cabinet. My microwave fried itself over the winter somehow so I just switched it out - I don't think it was over $100.
2015 Cummins Ram 4wd CC/SB
rhagfo
double post
rhagfo
We placed one in a cabinet no issues, current one is really in a cabinet also, as long as the fit isn't glove tight I don't see an issue.
zigzagrv
cpaulsen wrote:
Have installed 2 microwaves in 2 different 5th wheels and both were bought in big box stores that would fit the opening I had and never had any problems.
Sounds like you already had two m/w problems. ๐Ÿ˜‰ ๐Ÿ˜‰
Ron
2003 Gulf Stream Ultra Supreme 33'
F53 Class A
2013 Ford Edge toad
cpaulsen
cpaulsen
SCVJeff
I'm not sure there IS an "after market" MW. They are all one in the same
Jeff - WA6EQU
'06 Itasca Meridian 34H, CAT C7/350
work2much
Residential M/W are typically installed inside a non vented cabinet in a house. (not to be confused with a microwave that also acts as a range vent either venting back into the room or overhead through a duct and out of the roof typically) Did you old unit also have a power vent for the range?
RV units are 110v and plug in just like at home. Often they are mounted differently. You should be able to use any M/W that fits the space and offers a similar range vent (if any) as long as you can plug it in and secure it properly.
2022 Ram 3500 Laramie CTD DRW Crew 4x4 Aisin 4:10 Air ride.
2020 Grand Design Solitude 2930RL 2520 watts solar. 600ah lithium. Magnum 4000 watt inverter.
ScottG
Unless you run the micro for 20 minutes at a time, I wouldn't worry about circulation. I would buy a cheapo and go camping!
midnightsadie
mine is and I bought it at wal mart. works just fine.
