Missing vent cover all winter spring
rtreptow7
So I went in my camper and noticed the led lights in the bathroom ceiling were very dim and flickering...barely working. A closer inspection finds the lens filled with water 😞 I climb up on the roof and noticed there is some sort of round vent cover that is missing right above the bathroom allowing direct access to the inside of the ceiling of my camper. Probably been exposed like this all winter and spring getting snowed and rained in. Not sure what the vent is for. it is right in the middle of the bathroom area of the fiver. Inside the fiver there is no vent directly under the one that is mounted on the roof, it's just the middle of the bathroom ceiling. There is also another vent like this in the middle of the living area roof, but again, nothing on the ceiling on the inside of camper. I wonder how much water is trapped in the insulation in my camper ceiling now and if we have to worry about mold. Have an apt April 19 to have it looked at. Got plastic taped over it for now to prevent more water from getting in as it is raining now and supposed to snow some more this week even. First photo is of vent with missing cover, and second is the other vent that has it's cover yet. Does anyone know the purpose of this vent? Anyone have a similar experience?
Note: Moderator edit to fix picture URL's
2018 GMC Sierra Denali 2500HD Crew Cab 6.0L 4.10
2019 KZ Durango 1500 286BHD fifth wheel
2010 GMC Sierra 2500HD Crew CAb 6.0L 3.73 REPLACED
2004 Chevy 2500HD Exteneded Cab 6.0L 4.10 gears REPLACED
2004 KZ Frontier 2453P-F fifth wheel-REPLACED
19 REPLIES 19
austinjenna
I thought there were still a few of those vent covers that you can buy that were metal and not plastic although you might end up hearing the 'tinging' when it rains. M
2010 F350 CC Lariat 4x4 Short Bed
2011 Crusader 298BDS 5th Wheel
Reese 16K
shastagary
time for new ones RV Attic Mushroom Ceiling Roof Vent
this guy says to Put dab of silicone to help cover stay on.Howto Install an RV Attic Roof Vent Tip
BarneyS
The sun makes those vent covers very weak and brittle. The 2nd one should be replaced also. Good luck.
P.S. Use this site for posting photos on the forums. It is very easy to use and works great. I used it to fix your pictures above.
Barney
Not towing now.
fj12ryder
Maybe some kind of fan and hose to thread down into the hole to blow air down the hole and get some circulation. That could lead to mold and such when the weather gets warmer and it doesn't get dried out.
Howard and Peggy
"Don't Panic"
shepstone
It’s an Attic vent. And yes the insulation is going to need drying out.
2017 F350 Ruby Red Super Cab Dually 6.7 3.55 gears. B&W Companion 25K. BackRack. Gatorback mud guards. AUX65FCBRG aux tank. 2021 GD 380fl
2010 GMC Savanna 3500 extended 6.0
