Morryde pin box
Hammerboy
Just beginning to research replacing my pin box with a Morryde. Question I have is they tell you to order based on your units gvwr. I'm wondering if I am better off going with the size smaller than what my gvwr says. Loaded I would still be 1500# under using smaller size, so therefore would the correct size would be to stiff?
Dan
2019 Chevy crew LTZ 2500 HD Duramax
2017 Wildcat 29rlx fifth wheel
22 REPLIES 22
garyp4951
Use this to get the right part number MoRyde pinbox. Mine is 16k gvw on a 11k 5er and works great.
http://www.morryde.com/uploads/downloads/1415133016-PinBoxIdentificationGuide.pdf
Hammerboy
The only reason I was thinking of going to the smaller ones is because the smaller one is within 400 pounds of my gvwr but yet 1500 pounds in reserve over real world weight. But it sounds like a question for the Moryde reps. And I'm sure they'll tell me the same thing as I'm hearing here - to go with the actual size needed. Only reason I ask is because I heard of some owners having to go to the lighter rubber pucks because it was too stiff. I will definitely start out with what Morryde says to do.
Dan
23mikey
Don't pick the pin box based on how you load the vehicle, size it for the GVWR. If you undersized it and the next owner has a pin box failure, guess whose gonna be liable for all the damages??
Travel safe!
Mike
2018 F350 DRW Lariat PSD
2019 VanLeigh Vilano 320GK 1200w Solar, 400aH Battleborn, 3kw Magnum Hybrid Inverter/charger, Disc brakes, Sailun G rated tires
jims1
call them and ask about your RV. They know what series will work best with what weights.
Volvo dually Pickup
DRV Memphis
Me, Alie, and Salie
Fulltiming
greende
I have that pin box aND it works well. Do what Mor Ryde says and order based on GVWR.
2011 Chevy 3500 HD LTZ Duramax/Allison Crew Cab Long Box DRW
B&W Turnover Ball with Companion
2012 Keystone Cougar 293 SAB 5er
USAF 1968 - 1972 Viet Nam '71 - '72
GrumpyandGrandm
Going too small will give you more pulsation when you stop and go.
Grandma in front of her retirement home..
She lets Grumpy drive!!
Hammerboy
Not thinking cheap, they are all the same price I believe. My point is I don't want it too stiff to the point it's not doing its job.
Dan
donn0128
Your thinking cheap. Think instead safety. Order, or buy at least equal to or greater than the fivers GVWR
