Nationwide is not on our side
bobinraymoremo
I just got off the phone with Nationwide Insurance and they have denied any coverage for our black tank overflowing into the bathroom and up the vent and into the ceiling. They will send a letter but reviewed it over the phone. Denied for two reasons; mechanical failures and improper maintenance. There were two mechanical failures they stated; the vent not properly fitted to go all the way to the roof and because the check valve below the toilet did not work properly. I told them this was an RV toilet and not a home toilet and that there is no check valve. Was told this would not matter because of the other mechanical problem which is true, it should have gone out to the roof. The improper maintenance is leaving the water running after a black tank flushing. I told when I called in the claim that I thought I turned off the water but my improper maintenance leaving the water on and exiting the scene led to the loss which they will not pay for.
He also said that no insurance company would ever pay for this type of loss.
Thoughts, besides getting a new insurance company.
Bob & Jo (Full-time RV'ng since 09/10/2009 and loving it!)
Our travel blog: http://bobandjotravelblog.blogspot.com/
Our travel photos: http://www.flickr.com/photos/bobandjotravel/sets/
Our RV-2010 Carriage Cameo F35SB3
Our Tow Vehicle-2010 Ford F-350 DRW
27 REPLIES 27
cjoseph
If I leave my bathtub running and the overflow doesn't handle the volume of water, I'm SOL?
Accidents happen, that's what insurance is for.
The vent is not for the discharge of sewage. It is not a pathway for liquid. It is not an overflow. It was working perfectly fine. I'm sure air was passing quite well.
I say BS on your company. Who's to say the weight of the liquid didn't cause the vent stack to slip down. It wasn't designed to hold the weight of sewage.
If they will cover your "stupidity" (sorry), they have to recant the maintenance rejection.
I don't know how many vent stacks will hold the weight of sewage without slipping a little. They aren't put in that solidly.
Good luck to you.
Chuck, Heidi, Jessica & Nicholas
2013 Tiffin Allegro 35QBA
Sledge_Hammer
Super_Dave wrote:
"Accidents" might be better defined as action outside your control. Somewhere in the fine print, I'm sure the policy says it doesn't cover "stupid". When I do something that qualifies as, "stupid", I'm pretty prepared to have to pay for it myself.
I am a retired (last August) Director of claims. Insurance does cover stupid, as most accidents would fall into this range. The policy likely provides all risk coverage, thus there must be a specific exclusion to exclude coverage. Insurance companies have a lot of new trainees and often they are over exuberant. Raise the issue to the next level and if not satisfied take it to your States Insurance Department for a formal complaint. If the Insurance Department agrees that there is no coverage, than that is the way it is and no other company is likely to have coverage either. In a typical home owners policy, water which backs up through sewers and drains is a specific exclusion. Quoting the mechanical break down exclusion seems odd in this case, but the details might indicate otherwise. If it was a mechanical breakdown and it wasn't due to poor maintenance, then the manufacturer should take care of the issue. Continue to push the issue.
2013 Fuzion FZ315
2013 Ford F350 DRW
Pauljdav
Often there is an OOPPS clause. I would get mor information and discuss with others.
Insurance companies are in it for themselves and do use anything we say against us in a claim.
Good luck.
Paul
midnightsadie
theres good and not so good answers. if it was me I,d call back and want to speak to some one that knows rv,s . I,m real lucky ,MY agent would be handling this. I live in a small town. and I,ve done a stupid thing couple times. agent says ,don,t worry I,LL HANDLE IT. and he did.quote after all that,s my job.
laknox
At the same time, if you put your car in D when you meant R, I'd be willing to bet that your car and/or homeowner's insurance would cover you. That's pretty "stupid", IMO. 🙂 I think I'd fight this one all the way. At minimum, I'd say, "show me the specific fine print" =and= compare it to my last printed copy. I've known a couple people who've had terms changed on them without notice, then had the company deny a claim based on the =new= terms. If the company were any kind of customer-service friendly, they'd pay the claim, then go after the manufacturer.
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
bfast54
Yep.....Note to self....is what you need to do now......NEVER do this again....
Lessen learned?????????
2000 Ford SuperDuty F-350 Powerstroke,Dually.C.C.,.The Tow Monster
2005 Open Road 357RLDS
Prodigy Brake Controller:B
Honda EU3000is Generator
Raytek ,,Garmin 7735/GPS
Doran Mfg-RV360-TPMS
B&W/Companion
Rally's attended so far-21
My Blog
Good Sam Member
Klueck
I used to be an insurance adjuster, and yes, we do pay for stupid. I'm not calling you stupid, so please don't take offense. I'm not exactly sure what happened, but if you leave the car in neutral and it rolls down into a swimming pool, it would be covered. Yes, it might have been stupid, but it would have been covered. It was sudden and accidental. A maintenance issue is not sudden and accidental.
Again, I do not know the whole story, but from the little I read it sounds like they might be correct to deny the claim. If you don't feel they are being fair, you could certainly ask to have the claim reviewed. Read your policy and try to understand the exclusions portion. Then get a good understanding of what actually caused the problem. You might be able to determine if coverage should apply or not. Just because it was denied once, doesn't mean you can't dispute it. Good luck.
Hondavalk
Not to sure about that definition of an accident. I believe it's the intent that defines wether it's an accident or not. In cars people turn into your path, back into you, run into you, all events that were in there control. I gotta believe most insurance claims are paying for stupid.
dahkota
My manual states not to leave the gate closed when flushing the black tank and not to leave the water running unattended. In fact, I think both are on a sticker stuck right next to the flush hook up. You must have been gone a while...
I would chalk it up to a learning experience and move on...
2015 Jeep Willys Wrangler
2014 Fleetwood Bounder 33C
States camped: all but Hawaii
more than 1700 days on the road
wildtoad
I agree with Nationwide on this one seems like a self inflicted wound.
Tom Wilds
Blythewood, SC
2016 Newmar Baystar Sport 3004
2015 Jeep Wrangler 2dr HT
Denny___Jami
2X
Denny
2013 F350 SC DRW 6.2 V8 4.30 gears Air Lifts
2003 HitchHiker Premier 35FKTG 215/75/17.5 Goodyear G114 Tires
Super_Dave
Truck: 2006 Dodge 3500 Dually
Rig: 2018 Big Country 3155 RLK
Boat: 21' North River Seahawk
Swamp_Man
This really depends on what your policy says. Read it closely and see what exclusions are included. I have seen in my law enforcement days, where insurance companies paid for cars, damage, and repairs where a car was driven through a garage wall and into a swimming pool. But, with extended warranties, you have to read the exclusions. The vent pipe not going through the roof is a manufacturing defect. No a maintenance issue in IMO.
Leaving the water on in the black tank flush is an accident. Insurance is supposed to cover accidents. If everyone was perfect and we lived in a perfect world, we would not need insurance.
Steve & Trudy Jackson
2018 Cyclone 4005
2016 Ford F-450 6.7 PSD
AirSafe 25K hitch
