โAug-05-2015 01:05 PM
โSep-14-2015 01:09 PM
โSep-14-2015 12:24 PM
โSep-13-2015 07:01 PM
Dirtclods wrote:
OK call these people 714 259-1385 as mention above (Spin welding is the process) 07 Attitude 19" fresh water tank issue they took care of it. Pull your tank it tanks like 45 minutes, drive it over it well cost like maybe $30 bucks headache gone! Don't waste you time trying to glue it, they don't hold with everything flexing I tried it a waste of time!! http://www.ronco-plastics.net/
โAug-08-2015 02:54 PM
โAug-06-2015 07:12 PM
midnightsadie wrote:
if its easy to get to? they make BARREL flanges, , you cut a hole in the tank,I,d cut the old plug out and put one in. also boat flanges .
โAug-05-2015 08:48 PM
โAug-05-2015 06:20 PM
I just looked on ebay,, there called thru the hull flanges.
โAug-05-2015 05:32 PM
โAug-05-2015 05:28 PM
โAug-05-2015 04:30 PM
โAug-05-2015 04:09 PM
โAug-05-2015 01:52 PM
motogeek wrote:
Hello all, I am in need of some help. I have an 07 attitude 26FSAK. The fresh water tank is leaking from the fitting going into the water pump. The fitting is (i think) a 1" female bung that is glued into the tank. There is a 90 elbow that threads into that and the hose comes off from the elbow going to the water pump. The female fitting is cracked down the side where the threads are. I dont know what the tank is made of, just that it is a black plastic. The fitting is a clear or white color. Any advice is appreciated.
