Different woods take stain at different rates. First is it wood or is it a vinyl wood look alike over particle board.
If it is wood, , you best bet is to take a sample to a local paint store with a blank piece of unstained wood. The fellows there can help with a Minwax stain or even a mixture. I installed a pair of doors that I had made by a local cabinet maker and wound up mixing two different stains to get the proper Light Cherry match. It took about 4 or 5 mixes to get it right and the match is perfect.
I got a scrap of the wood from the doors to make trial stains. I lined up several small plastic containers and used a 1/8 teaspoon to count out the mix ratio. I wound up at 6 of part A and 1 of part B to get a match.
If is the fake wood, get some of the touch some acrylic paints and mix aand match until you have the right color.
Good luck.
Ken
Amateur Radio Operator.
2023 Cougar 22MLS, toted with a 2022, F150, 3.5L EcoBoost, Crewcab, Max Tow, FORMER Full Time RVer. Travel with a standard schnauzer and a Timneh African Gray parrot
