Need hitch weight
Ofischill
I have a 1994 Newmar American Star 25ft fifth wheel, model 25WRKDFW, which has one slide.
What is the hitch weight of the unit?
5 REPLIES 5
MFL
Nomad II
Nomad II
That FW will be a bit much for most 1/2 ton trucks. The hitch will add more wt, on the rear axle, likely putting the 1/2 ton over RAWR. If he has one of the older (fake) 1/2 tons, with 7-8 bolt axle he would be fine.
Sounds like a nice older FW, hope it works out for him.
Jerry
Ofischill
I have the unit for sale and the potential buyer has a half ton short bed. I did not encourage him using that truck especially if he has plans to pull it on a regular basis.
Second_Chance
Old-Biscuit wrote:
Dry weight----------- 8200#
Dry pin weight------- 1700#
GVWR---------------- 10,400
Pin (20% of GVWR)--- 2080#
Actual numbers hard to find...above are based on 2000 similar model
Verify GVWR by looking on sticker left front side.
This is a good place to start. Depending on how you load, pin weights can range from 20 - 25% of the trailer's GVWR. We're at 23% and don't have a generator or W/D - loaded pretty moderately, actually.
Rob
U.S. Army retired
2020 Solitude 310GK-R
MORryde IS, disc brakes, solar, DP windows
(Previously in a Reflection 337RLS)
2012 F350 CC DRW Lariat 6.7
Full-time since 8/2015
Ofischill
Thanks. Yes the GVWR is 10,400.
And there is no sticker outside anywhere. The sticker is on an inside cabinet door.
Old-Biscuit
