Norcold 2118 frig error code li-op.
Brinksongs
I just got my Montana 3402 w/ a Norcold 2118 refrigerator. Only had 5 days and today got an error message on the front panel of "li- op" says it is the high temperature limit switch problem. Is there a way to reset? Thanks. Brink
5 REPLIES 5
lj2654
these high temp boxes are terrible, Think they are on revision"f" maybe now. I have an "E" and my red light came on with the frig turned off, overheat when off, yea right.....
2001 Beaver Contessa Naples 40
2012 Cadillac Srx
retired AirForce 1979-1992
Brinksongs
Thanks...will do :). Brink
Old-Biscuit
Brinksongs wrote:
2015 Montana 3402. Red light is on when refrigerator power is on. Bought new and have only had 5 days. Dealer closed today.
Contact them tomorrow AM......
Keystone warranty....PLUS Norcold warranty
Probably bad electronic in box.
Only Norcold authorized service can verify/replace
Brinksongs
Old-Biscuit
NEW or USED RV??? What YEAR????
High Temp Limit Switch......OPEN
Means that temp switch has detected a very high temperature at perk tube/stack. That means that fridge cooling unit has failed (blockage/crack tubing)
OR
High temp controller has failed
But which one........real hogh temp or faulty device??
Do you have a 'Box with RED LED light ON' in outside compartment?
Can reset using a strong magnet.......place magnet against face of box and move back/forth until you hear 'click' and RED goes OFF
This will restore 12V DC to fridge and allow operation
BUT:
CAUTION: YOU NEED TO VISUALLY INSPECT COOLING UNIT TUBING/BURNER STACK/BURNER AREA FOR ANY YELLOW RESIDUE, ANY AMMONIA SMELL-------THAT MEANS CRACKED/BAD COOLING UNIT
DO NOT USE FRIDGE>>>>>>>>>>>>>>>>>>FIRE HAZARD
OR have an RV TECH Inspect and then if just faulty device vs bad cooling unit they can contact NORCOLD for replacement
