nylon disc
Dick_641
Just got a new B&W hitch an was wondering if there is one nylon disc better or are they all about the same. Had a pullrite hitch before so never used one.
8 REPLIES 8
frizzen
How would it work to make one out of a cutting board?
I need some wild
packnrat
yes, far better than grease.
even if you over pay at a rv dealer. they are worth it.
great thought, bottom of a five gallon bucket.
2006 F250 4X4 auto 6.0 short bed
2001 sunnybrook 24 ft
1984 cj7 built up a bit
kg6tgu
never too many toys, just not enought room to keep them
one dog who belives she is the master. rip 12 12 2007
12 loving years and loyal to the end.
just out having fun
Cummins12V98
Dtank wrote:
Cummins12V98 wrote:
If you want to save a buck cut the bottom out of a 5 gallon bucket. the circle on the bottom is the exact size to cut the hole. I have one as a backup.
Put that on your Bucket List..:W
Good one!
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Dtank
Cummins12V98
Great call on the B&W!
The jaws are so thick on the B&W that the standard 1/4" thick disk makes it hard to see when the weight is off the hitch. Hensley sells a 1/8" thick disk that is not cheap but it does make it easier to unhitch. Some will say they have no problem with the 1/4" disk and B&W. I am saying it makes it much easier!
TheAmRheins
I like the orange one that is attached to the hitch.
Ken & Kathy
Ruben(the cat)& Tiadora (nother cat)
2003 Chev 3500 D/A Dually
2009 Landmark Augusta
drfife
I've tried two different 5th wheel lube plates. The traditional Reese white nylon and the black Whisper Disk from Lippert.
I had retention issues with the Reese on my B&W Companion.
The Whisper disc is very nice and seems to wear less.
I prefer the Whisper disk, but it is more expensive.
Russell
'12 GMC Sierra 3500HD SRW
'13 Excel Winslow 34IKE
MTPockets1
Nylon is all the same. Get the correct size to cover the pin box plate
2012 3055RL Big Horn - Dexter upgraded axles - G rated LT Tires
MorRyde, Genset, Dual Panes, 2 A/C, Yeti Package
2013 F350 DRW 4x4 Crew King Ranch
