odd water pressure
tomthyme
Ok, guys - I am totally stumped!
Our water pressure is wacky (on city water). When we run the cold, we get ver low pressure, when we run hot, we get almost twice the pressure. I've cleaned the diffuser thingy at the end of the faucet at the sink, but have no idea why there could be such a difference. Shouldn't the pressure be the same regardless of cold/hot feed?
Pressure seems to be the same confusing situation at all water outlets.....maybe one of the feed lines is full of gunk, lime, etc.?
So confused.
Thanks so much!
Tom
2015 F350 King Ranch Dually 4x4, 22k Reese hitch
2011 Carriage Cameo 37cksls
Sarah (most beautiful creature in the world)
Mickey (105lb golden - good thing he's pretty)
Ashlee (85lb lab - spectacular pal)
Dutch (120lb lab - young one in training)
8 REPLIES 8
Old-Biscuit
kimbo1 wrote:
check for open valve somewhere, valve to tank fill?
That would account for low water pressure.........but would affect hot just as much as cold.
Low cold pressure and hot OK just doesn't make logical sense.
Hope OP finds the cause and posts
kimbo1
Old-Biscuit
Do you have same low pressure issue on cold when using on-board pump?
Is toilet affected by this low pressure/flow issue also????
City water feeds main cold water line off of which sinks/showers/toilet & water heater 'T' for cold-side supply. (pump discharge ties into this main line)
Cold goes in bottom of water heater and then out top to feed main hot water line off of which sinks/showers 'T' for hot-side supply.
Cold water low pressure/flow issues should affect hot water pressure/flow also.
Might need to disconnect cold line to sink.....place in bucket and then turn water supply on. Check pressure/flow into bucket. Good flow-----then faucet could be plugging on cold-side port.
Try at each faucet/shower.
Has to be something got into main line and clogged up cold side faucets.
Plugged system filter would affect hot/cold
City water inlet problem would affect hot/cold
okiejoe
I would say that as water gets hot in the tank it creates pressure and maybe that's why you may have more pressure on the hot side.
Harvard
Weird stuff happens when there is an outside shower where the shower head is OFF and both HOT and COLD taps OPEN.
Allworth
We have a factory installed filter on the cold supply under he sink. Had to replace the cartridge last Spring.
Could Carriage have put some kind of filter on the cold supply somewhere?
Formerly posting as "littleblackdog"
Martha, Allen, & Blackjack
2006 Chevy 3500 D/A LB SRW, RVND 7710
Previously: 2008 Titanium 30E35SA. Currently no trailer due to age & mobility problems. Very sad!
"Real Jeeps have round headlights"
tomthyme
beechmanbopp wrote:
Any loose screws anywhere?
in my head for sure, but where else should I look?
beechmanbopp
