Off season storage on jack stands?
DCamp84
Ok let's try this again. Being new to forums and trying to work everything from a "smart phone" is getting me in trouble lol. I had a question I thought of on my way to work this morning. How many (if any at all) store your fivers up off the ground on jack stands during your off season. Would you recommend it? Is this even a correct method of storage? If so, would the continuous weight/ pressure on the points of contact hurt the trailer in any way? Ps. I have a dirt driveway. Thank you for your input
Damon,
Long Island, NY
2011 Keystone Copper Canyon 5th Wheel
2008 Chevy Silverado 2500HD Duramax LTZ CCSB 4x4
Pullrite SuperGlide 4100
15 REPLIES 15
otrfun
laknox wrote:
"ST" is a trailer-only tire; "special trailer". Frankly, the vast majority ain't so special; they're junk. If you have anything with 16" wheels, you can put LT (light truck) tires on them and get much greater longevity and peace of mind with them than with most STs. That being said, there are a couple brands of ST tires, especially in the 15" size, that are much better than the rest. Maxxis is probably top of the heap, though they still have the 65 mph speed rating and they do have occasional failures for, seemingly, no reason. Carlisle, which was one of the worst a decade ago, came out with a completely re-engineered ST tire line that is, IMO, the equal of the Maxxis, despite being made in China (Maxxis is made in Thailand and/or Taiwan, IIRC). I have a set of Carlisles on my FW, going into the 4th year, and they have a bit of weather checking, but otherwise look, and tow, excellently. The Carlisles also have a higher speed rating, into the high-70's/low 80's, so that tells you something, too. Not that I tow that fast, but if I stay at my usual 60-65 mph, I should have plenty of "safety margin".
Lyle
Agreed, 90 percent of the "ST" tires out there are "D" and "E" rated tires that have rightly earned their less than stellar reputation.
However, the other 10 percent are G-rated, ST tires like the Sailun (prefix recently changed from LT to ST), Gladiator, Hartland, etc. These tires are speed-rated from 75 to 87 mph and have an excellent reputation--especially the "all-steel" versions. A documented failure of an "all-steel" G-rated, ST tire, like the Sailun, are very rare.
C_Schomer
I stored my fiver off the ground for four yrs, anytime it was home, with the tires covered. Those sts were only on the ground for about one month in that four yrs and they still blew apart at four yrs, to the month, just like the prvious set that were always stored with all the weight on them. It's a waste of time with sts. Craig
2012 Dodge 3500 DRW CCLB 4wd, custom hauler bed.
2008 Sunnybrook Titan 30 RKFS Morryde and Disc brakes
WILL ROGERS NEVER MET JOE BIDEN!
JIMNLIN
Goodyear storing tires
Every tire maker has there recommendations on how to store their tires...and they all say about the same thing.
I make sure my tires on all my rv/GN and other bumper pull trailers are at max sidewall psi 24/7 especially my 11200 lb RV when it sits from oct to april. The tires sits on wood with a gravel pad in a covered shed. The tires never sees the sun when stored.
I jack the end of the axle and rotate the tires 45 degrees a couple times a winter. I use LT tires and run them 50k-55k miles in a 7-8 year period.
Jacking the trailer was much more common years ago.
laknox
DCamp84 wrote:
laknox wrote:
Damon,
Long Island, NY
Easiest thing to do is to run your wheels up on some boards, dress the tires with a =good= protectant (i.e. NOT a "shine", but an actual protectant, like Aerospace 303), then cover them completely. If you'll be in and out frequently, drop the rear stabilizers...or not. With ST tires, I don't think it makes a hill of beans difference if you put 6 or 8 jack stands along the frame and took the tires off and stored them inside; they're going to "age out" (almost NO RV tires actually wear out, unless there's another issue going on) after 5 or 6 years and you'll need to replace them.
(cynic mode off)
That being said, I've run a set of cheap ST tires for right at 6 years before they all 4 went bad in about a week, fortunately while I was moving my FW from storage to my house and some short "town trips". I knew I was pushing things and I didn't get burned, but I certainly could have.
Lyle
Thanks Lyle! Just to clarify the "ST" when you say "ST tire". What does that mean.
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
Veebyes
The first couple of winters of ownership I went to the trouble of lifting the trailer to a point of little weight being on the tires & using jack stands.
Don't do it anymore. The trailer & truck are stored indoors. On the wheels & legs, good enough.
2007 Alpenlite 34RLR
RAS43
We have had trailers of all kinds for 40+ years and I have never stored them on jacks or without tires/wheels. I park them on gravel and currently have old rubber mud flaps under the tires just cause I had some. I have never seen any tire deteriorate any sooner because of this. Time, sun and ozone are the enemy. I do cover them.
BB_TX
I am very much an LT tire fan and have them on my 5er. But be aware that ST tires are often rated for a higher load rating than an equivalent size LT tire. If you choose to go with an LT make sure the tire load rating is adequate for your purpose.
DCamp84
Gotcha A. That's true. LT tires are definitely worth looking in to
DCamp84
Good point. Thanks Bill!
Allworth
"ST" is a Special Trailer tire. As in ST235/85 R 16.
ST - tire type. In this case Special Trailer. As opposed to "LT" Light Truck or "P" Passenger.
235 - tread width in MM.
85 - Aspect ratio. Sidewall height compared to tread width as a percentage.
R - Radial construction.
16 - wheel diameter.
Others will say differently, but after fighting defects in ST tires for six years (long ago) I switched to U.S. made LT tires and have had no problems since. (LT245/75R16)
IMHO almost all ST tires are made overseas (in the far east) where quality control is less than outstanding. DOT does not require any excess capacity beyond the load rating on the sidewall for ST design and the max speed rating is 65mph.
LT tires have heavier construction; safety factor above weight limit; higher speed rating; and a MUCH better reputation in RV service.
Let the rebuttal begin!
A
Formerly posting as "littleblackdog"
Martha, Allen, & Blackjack
2006 Chevy 3500 D/A LB SRW, RVND 7710
Previously: 2008 Titanium 30E35SA. Currently no trailer due to age & mobility problems. Very sad!
"Real Jeeps have round headlights"
Trackrig
I use 303, cover the tires and disconnect the batteries on both the MH and TT - that's it. If you weren't going to use one of your cars for 3 - 4 months, would you block it up?
Bill
Nodwell RN110 out moose hunting. 4-53 Detroit, Clark 5 spd, 40" wide tracks, 10:00x20 tires, 16,000# capacity, 22,000# weight. You know the mud is getting deep when it's coming in the doors.
DCamp84
laknox wrote:
Damon,
Long Island, NY
(cynic mode off)
Lyle
Dick_B
I think RR ties are better (more stable) than jack stands.
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
BB_TX
Mine has been stored from Oct to April every year since 2007 setting on the tires and front jacks only. Mine sits on gravel. No need to do otherwise. Only thing I would do in your case is put some boards or large square concrete paving stones on the dirt under the tires and front jacks.
