oxygenated cleaner
bikernut
I saw some oxygenated cleaner on utube that you mix this item with water, wet the area first and then spray this stuff on. let it soak for a couple of minutes and lightly scrub with brush and hose away the dirt and grime.
can this stuff be used on my rubber roof without hurting it and does it need to have some sort of sealer applied after.
it looks almost to good to be true
2007 KZ New Vision 41kg Sportster toy Hauler
1995 FLTC
1992 Chevy S-10 Blazer 4X4
1987 Pontiac Trans Am GTA w/19784 miles
2020 GMC Denali
2015 Harley Tri-guide
3 REPLIES 3
bikernut
this is not Oxiclean it goes by the name "WaterSeal" and you get it at big box stores or lumber yards and it it put out by "Thompsons".
To clean outdoor surfaces, use concentrated oxygen powered cleaners, like this one, to remove dirt, mildew, algae, fungus. They are chlorine-free and biodegradable.
This cleaner, WaterSeal by Thompson's.
this is where I saw it http://www.ronhazelton.com/projects/how_to_clean_outdoor_surfaces_using_oxygen_cleaners/
1995 FLTC
2020 GMC Denali
gmcsmoke
Dick_B
Oxyclean? Does wonders on all kinds of dirty surfaces. Don't know why it would not work on the roof. `Soft Scrub with bleach' works so Oxyclean should work also.
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
