Pocket door
dsnuggles
So I have a 2017 Fuzion 369 and the master bedroom door is a pocket one. I wanna put a lock on it, but I can't seem to find one yet. Have anyone on here put a lock on their door and what kind?
7 REPLIES 7
Bedlam
Moderator
Moderator
My Arctic Fox pocket door on the bathroom used one like this one around $10:
Even simpler is this for under $5:
Gearheadzs
Here is what I used, search:
Kwikset 335 Round Bed/Bath Pocket Door Lock in Satin Nickel
Cost around $19.00, Home depot or Amazon
Install is pretty simple, works great to keep privacy and unintended walkins.
Good Luck.
Gear
2014 Voltage 3818 (Epic I & II)
2005 Fleetwood 31ASV BP Toy Hauler
2017 Ram 3500 Longhorn DRW, 4x4, 3.73, Aisin
4 Seat Long Travel Sand Rail, 97 Jeep TJ Rock Crawler, 68 Roadrunner, Various Quads
nayther
Ours has a lock on it, never used it then one day the DW closed it and it locked, broke the lock actually and she was stuck in the bedroom. Had to pry it open. Fortunately didn't hurt the lock/pull cosmetically but the lock is toast now, I need to pull it off and gut the lock mechanism for now it's held up/out with electrical tape.
DIRT BIKES RULE
'12 Duramax CC short bed
2019 Wildcat Maxx 285RKX
eDUBz
Locking the kids out - good times in the desert ๐Ÿ™‚
LBZ - Stealth TH - RZR 900 4 - Honda 450X - Paddleboarder - Fisherman - Kayaker
dsnuggles
joebedford wrote:
Depends on whether you're trying to lock somebody out or in.
Both.
joebedford
Nomad II
Nomad II
George_H
Various degrees of fancy, a bolt type lock either into floor or door frame. You want to lock in position when traveling, otherwise it may come off of track, same type of lock can be used for privacy.
George, Juanita and Mandie (boss Shar-Pei)
01 F350, PSD, DRW
05 Carri-Lite 32RS3
