Poliglow Prep for oxidation
dpam
Thinking of using Poliglow Prep to remove oxidation and old wax from the front of the 5th wheel. After using Poliglow Prep I am planning on applying new wax. Has anyone used Poliglow Prep to remove oxidation and old wax? Has anyone applied Poliglow after using Poliglow Prep.
Appreciate your feedback.
DPAM
19 REPLIES 19
jjj
I used bars keeper friend to remove lots of oxidation. Then follow with a good wax. It worked pretty good. You will never get that full shine again. You will still have to keep doing this year after year unless you wax it every 3 months or so. Mine is 12 years old and one side always in the sun it fights me every year. The other side is always shaded and still has all its graphics but had to remove all faded and cracked graphics from front driver side and rear and fight oxidation all the time.
2002 F-350 Crew-Cab Dually
V-10-4.30 gears Mag-Hytec diff.cover
w/Amsoil-6.0 trans cooler Curt Q5 20K hitch & bedsaver
2005 Keystone Challenger 34TBH-Fifth Airbourn
missourijan
X2 on what donn0128 said. We tried it and couldn't get it smooth. Called the manufacturer and they weren't much help. We followed the instructions. Like donn0128 could never get all of it off. We used polishing compound and an orbital buffer on light oxidation
B_O__Plenty
The only real cure is to have the gel coat painted. Nothing else is a permanent fix.
B.O.
Former Ram/Cummins owner
2015 Silverado 3500 D/A DRW
Yup I'm a fanboy!
2016 Cedar Creek 36CKTS
4x4ord
Poly Glow is fast and easy and will give your RV a bit of facelift but it doesn't fix the problem. To bring a like new shine to heavily oxidized gel coat requires wet sanding followed by polishing and waxing. Waxing is done as a final step and should really be for uv protection rather than to restore a shine.
2023 F350 SRW Platinum short box 4x4.
B&W Companion
2008 Citation Platinum XL 34.5
donn0128
Did it once. Never again. Fought the mess after the first year. Never did get all of it off no matter how much stripper I used it seem to still be there.
