โJan-10-2014 05:50 AM
โJan-14-2014 05:18 PM
GaHighPockets wrote:
Thanks for all advice, best was the regulator....got and installed New one today and success.
โJan-14-2014 03:00 PM
โJan-12-2014 09:17 AM
โJan-11-2014 07:54 AM
โJan-10-2014 05:07 PM
โJan-10-2014 04:27 PM
sljkansas wrote:
I remember hearing something a while back about LP dealers down South uses butane instead of propane, and that butane doesn't like being real cold.
maybe someone can chime in on this. My memory sometimes mixes things up.
โJan-10-2014 01:29 PM
โJan-10-2014 12:52 PM
โJan-10-2014 12:40 PM
โJan-10-2014 11:04 AM
rhagfo wrote:Ka Ron wrote:
This does not sound like a propane issue, it sounds like a furnace issue.
Probably a sail switch??GaHighPockets wrote:
9) I suspected low gas pressure so I turned furnace back on, went out side and put hand over the fresh air intake for the furnace, it would light right up and make heat as long as I kept intake mostly obstructed.
I believe it to also be a propane supply issue, if chocking off the air supply makes it work, most likely not enough propane for combustion.
โJan-10-2014 10:59 AM
โJan-10-2014 10:55 AM
โJan-10-2014 10:47 AM
โJan-10-2014 09:46 AM
