Jan-26-2014 06:50 PM
Jan-26-2014 07:55 PM
Jan-26-2014 07:44 PM
sloman2001 wrote:
I am changing all my tires on out 5ver from STs to LTs. I have looked for an answer to my question but to no avail, so I will try here, you have all been helpful in the past.
I'm going to put 80lb psi in the tire per the RV recommendation. The max tire pressure is also 80lbs. I'm putting on Michelin LT235/85R16 size tires. They are load range E tires (3042 lbs. at 80 psi), I have 5200 lb. axles.
While driving, this pressure will increase to various levels depending on the ambient temperature as well as speed (we drive 55 mph).
So 2 questions,
1) What is an acceptable level of psi above the 80lbs, and
2) If the pressure exceeds that, do I merely stop and remove some air?
I do not want another tire failure.
I have a TPMS in place so I can monitor the pressure real time.
Thanks in advance. I'm learning the hard way.
Tom
Jan-26-2014 07:07 PM
Jan-26-2014 06:56 PM
