โMay-14-2014 08:08 AM
โMay-14-2014 05:52 PM
โMay-14-2014 05:28 PM
โMay-14-2014 01:18 PM
โMay-14-2014 01:14 PM
Campinfan wrote:
I use the BAL stabilizers and put two of them on each leg/jack. One goes along the front (or rear) of the rig and the other goes along the long side. that way they are set at about a 90 degree angle to each other. It stops the forward/backward movement, and the left to right movement. If you just use one, it only stops the movement in that direction. Maybe its overkill but it works
โMay-14-2014 01:10 PM
โMay-14-2014 12:46 PM
โMay-14-2014 12:16 PM
โMay-14-2014 10:30 AM
โMay-14-2014 10:25 AM
Scott_85 wrote:
When I get to the campground I've just been using one yellow pad or put under the landing gear and the rear jacks, then running the jacks all the way down, is this right or should I use more yellow pads? The reason I ask is because I can't seem to get the camper steady enough. I also use the x chocks. Is there anything else I can do just to make it a little more steady?
โMay-14-2014 10:18 AM
โMay-14-2014 08:20 AM
