Replacing 2 tires, where should the new ones go?
danr1707
Without getting into a long story, I have 2 G614 RST tires that need to be replaced. The other 2 are newer and in good shape.
Should I put the new ones on the front or back axle?
2018 Jayco Eagle HT 29.5FBDS
2017 F-350 6.7 4x4 CC LB SRW Lariat
2 Parakeets
Senior Member only because I've asked over 200 stupid questions!
21 REPLIES 21
DougE
Just put them both on the same axle then rotate them front to rear periodically to even out the wear.
BTW the accepted practice on the tow vehicle is to put the best tires on the rear. When towing, you really lose stability if a rear tire is low whereas you can use steering to correct for the effect of a bad front tire. If you've ever had a back tire go down you'll readily agree with this.
Currently Between RVs
ScottG
I asked this same question a month ago and most people thought the back tires tended to scrub and wear more - which was what I had observed as well.
Dick_B
Better to buy five new ones and rotate them all periodically. See www.michelinrvtires.com for why to include the spare.
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
midnightsadie
put four new ones on,
Grandpere
Sorry, I missed that it is for the trailer, so Fred is correct, position does not matter.
Berniece & Russell Johnson
Lil'Bit, a Netherland Dwarf Rabbit
1987 Southwind
1995 Ford F150 Supercab
Life in the fast lane? No thanks, we will stop and smell the flowers at every opportuity
Golden_HVAC
It is a trailer, so the tire position does not matter at all.
Fred.
Porsche or Country Coach!
Kangen.com Alkaline water
Escapees.com
Grandpere
new ones always go on the front axle because there is less chance of a blowout on the steering axle.
1987 Southwind
