Residential Refrig, not enough power
mksmitty1960
I have a residential refrigerator in my fifth wheel and running out of electricity in about two days. Currently running 2 six volts and have a 200 watt solar panel putting out about 8.7 Amps. I am considering the following upgrades, 4 Six volt batteries, adding a second solar panel and the possibility of adding a secondary battery charger to a 20 or 30 amp. I also run a generator about 3 to 4 hrs a day. In regards to adding a second battery charger, do you need to disconnect the original factory charger? Would this work?
Thanks, Mike
Did you see the "Announcement : ★★READ BEFORE POSTING HERE★★" located at the top of this forum?
    "Forum Posting Help and Support is reserved for questions related to forum posting, signature and photo testing, or reporting member account issues. Please avoid using Forum Posting Help and Support for RV related questions, as doing so can delay responses to your thread. Instead, post in the RV Forum which corresponds to the subject of your topic. Thank-you!"
10 REPLIES 10
TXiceman
Need 2 more 6 volt batteries and another solar panel or two. maybe a small generator to help recharge on overcast days. Also monitor all 12 volt use.
Ken
Amateur Radio Operator.
2023 Cougar 22MLS, toted with a 2022, F150, 3.5L EcoBoost, Crewcab, Max Tow, FORMER Full Time RVer. Travel with a standard schnauzer and a Timneh African Gray parrot
djousma
I'd also suggest focusing on ALL 12V consumption, not just the refrigerator. Could be something else with a big drain that you arent even aware of.
Dave
2016 F350 Lariat 4x4 FX4 SRW CC SB 6.7 Magnetic Metallic
2017 Forest River Cardinal 3850RL
kellertx5er
garyp4951 wrote:
Just switch it to propane.:)
It is a RESIDENTIAL unit. AC only, no propane.
Keller TX
'19 Chevy 2500HD 6.0L
'09 Outback Sydney 321FRL 5er
SUPPORT TEXAS STATE PARKS
full_mosey
mksmitty1960;
If you are a weekend camper/RVer you can extend your days by adding batteries.
When that is not enough, you add solar or run a generator.
However, you are already running a genny 3-4 hours daily.
You need to get a handle on your daily AH consumption or you will keep adding components with no clue.
What are your goals? Weekends or what?
HTH;
John
garyp4951
time2roll
I agree with 4x GC2. I agree with adding 200+ watts solar... max out your controller or the entire roof. For better charging I recommend a PD9280-14.8 converter upgrade. Upgrade your battery charging loop to #4 wire.
http://www.bestconverter.com/PD-9280C-148-80-Amp-RV-ConverterCharger
1492
Moderator
Moderator
theoldwizard1
pianotuna wrote:
I'd go to 600 to 800 watts of solar. Upgrade to four jars.
Concur !
GordonThree wrote:
Turn the fridge off at night to conserve power?
Excellent suggestion !
GordonThree
2013 KZ Sportsmen Classic 200, 20 ft TT
2020 RAM 1500, 5.7 4x4, 8 speed
pianotuna
Nomad III
Nomad III
Mike,
What type of converter is currently being used?
Often battery chargers and converters may "play well together".
Regards, Don
