roof coating
64thunderbolt
Anyone recoat their roof? What did you use? I just ordered the primer for epdm & topcoat. Kool Seal from KTS coatings. Hope it works. It needs something to get me through a few more years till I trade or reroof it. keeping my fingers crossed.
Glen
04 Tail gator XT 34' 5th wheel garage model
200w solar 2 GC2's 800w inv
Truma tankless WH
99 F350 CC DRW 7.3 ais intake, adrenaline hpop, JW valve body,
cooling mist water inj, DP tunes, 4" exh sys
trucool trans cooler added
2011 RZR 900xp
14 REPLIES 14
nayther
TBRam wrote:
rvroofingsolutions.com
He's been doing roof coatings for years with his own patented coating that's garanteed to never crack. Had him do my last travel trailer and highly recommend. You will never have to worry about your roof again. Call him and he'll send you a sample of his material. Plus it's done in your driveway. I'm not affiliated in anyway just a very satisfied customer, and I'm very fussy who does work for me.
They advertise on an RV weekly newsletter and have a youtube video, very impressive. probably pretty expensive though.
DIRT BIKES RULE
'12 Duramax CC short bed
2019 Wildcat Maxx 285RKX
TBRam
64thunderbolt
After checking the membrane I am gonna wait until the end of this camping season to recoat it. Too many other things going on. need to put injectors, glow plugs and harnesses in my brother's truck.
Glen
Truma tankless WH
2011 RZR 900xp
64thunderbolt
Here is the roof before pressure washing. The white material is a coating applied by someone prior to me buying it. It started coming off every time it rained. I will add an after washing pic tomorrow. It was getting dark so I will get one before applying the new coating. The membrane is in good condition but just dark from the sun. Not sure why they coated it but it is time now.
Glen
Truma tankless WH
2011 RZR 900xp
64thunderbolt
This is what a friend used and it has held up for several years. Clean, apply primer for rubber roof then apply. I bought 5 gal, enough for 2 coats @ Amazon for I think $148.00. Several reviews on Amazon on rv roofs. I suppose I will find out.
check here
Glen
Truma tankless WH
2011 RZR 900xp
64thunderbolt
another try
Glen
Truma tankless WH
2011 RZR 900xp
64thunderbolt
oops couldn't link
Glen
Truma tankless WH
2011 RZR 900xp
64thunderbolt
bkirkpatrick wrote:
Take some before and after pics and also what you had to remove up top (ie. AC covers, etc.)
I will remove a/c cover & 2 vent covers. Fridge cover has enough room to get to flashing & I have 2 fantastic fans that I will cut in around without removing. I will be removing a small solar panel as I have a new 200w system going on after the recoat. I will get some pics. It will be within the next 2 weeks.
Glen
Truma tankless WH
2011 RZR 900xp
64thunderbolt
bkirkpatrick wrote:
That is actually a good idea but I don't know about the weight of it and how it would hold up to any flexing.
https://www.amazon.com/gp/product/B001B1CHLW/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
5 gal wghs 30# so I don't think 30# distributed over the entire roof is a issue.
Glen
Truma tankless WH
2011 RZR 900xp
64thunderbolt
Macman83 wrote:
I have read about people having Rhino coating put on the roof. It sounds like a workable idea to me. If it will last in a truck bed, it should last on the roof of a trailer.
I truck bed doesn't expand & retract like our roofs do & is not flexible enough I think.
Glen
Truma tankless WH
2011 RZR 900xp
Y-Guy
Moderator
Moderator
Previously discussed and accomplished.
onearmyrider's 2006 37? Weekend Warrior 5th Wheel He was active through part of 2013 and then deployed, haven't seen him back on since.
Two Wire Fox Terriers; Sarge & Sully
2007 Winnebago Sightseer 35J
2020 Jeep Gladiator Rubicon
bkirkpatrick
Macman83
2010 Ford F450 Superduty diesel
2013 Voltage 3905
bkirkpatrick
