Apr-15-2015 09:59 PM
Apr-22-2015 05:14 PM
Apr-22-2015 02:22 PM
mrw8i wrote:
There is an online video about installing Strong Arms. The holes are front to back.
Strong Arms Install Video
Apr-22-2015 01:59 PM
Apr-22-2015 12:44 PM
NWKomfort350 wrote:laknox wrote:4x4FF wrote:
Here is a pic of how mine currently is:
I'm no expert, but I can't say I've =ever= seen a FW without the pins facing outward.
Lyle
The pins in the landing gear legs on my 5er are side to side.
Apr-18-2015 06:11 PM
sdfiver wrote:
4X4FF;
Our new 5th came with factory installed JT Strongarms. Unless the aftermarket kit is different from the OEM kit I'd say your landing gear legs are correctly oriented for the Strongarms.
The lower arms attach to the back of the legs with the nut on the front of the leg. You'll have to enlarge the lowest hole to 1/2" for the through bolt if it's not that size already.
You may have to move your 5" fence post sewer holder as the arms may hit it when you have the gear retracted. Hard to say from your pictures.
Ours has the Snap-pins facing forward by the way.
Apr-18-2015 10:40 AM
Apr-16-2015 01:46 PM
Apr-16-2015 12:59 PM
Apr-16-2015 11:01 AM
Lyle
Apr-16-2015 09:22 AM
Apr-16-2015 07:57 AM
Apr-16-2015 06:57 AM
TT_Tim wrote:
I helped a buddy put JTs on his 5ver and his were rotated 90 degrees from what mine were. We simply put the "saddle" bracket on the front cross pieces instead of the back. worked good.
Apr-16-2015 06:23 AM
Apr-16-2015 05:07 AM
