Aug-20-2019 12:14 PM
Aug-23-2019 05:36 AM
Which Provider do you like?
Lyle
Aug-22-2019 08:39 AM
pyoung47 wrote:
Thanks for all of the replies. I'm going to play with air pressure a bit, and see if I can mitigate some of the issues. Selling/replacing the tires is not a realistic option, since I don't want to throw $700-800 bucks away.
Aug-22-2019 07:47 AM
Aug-21-2019 12:02 PM
Aug-21-2019 11:14 AM
pyoung47 wrote:
Last fall, I installed a set of Sailun tires on my Montana, upgrading to G rated tires. I’m running only 90-95 pounds in the tires. They are shaking the camper quite a bit. Last week, we cravked three crock pots on the way home. Does anyone else experience this?
Aug-21-2019 09:49 AM
Aug-21-2019 09:08 AM
JIMNLIN wrote:
JMO but from my experience I would say way too much tire for the job.
The Sailuns (4080 -4400 lbs capacity) work best for 7k and 8k axles but not the best idea on trailers with light loaded 6k-5.2k axles.
I got into the over tire issues on my tandem axle cargo trailers with 5.2k axles with 15" OEM load C tires.
My other trailers (heavier) with 6k-7k axles had 16" tires so I moved both cargo trailers (our job site tool trailers) to 16" E tires. After that move we found tools scattered all over the trailers floor. At that time we had many 15" LT tires available so went to a 15" C load tire. No more tools shook loose from their hangers/shelves.
I would put those G load Sailuns on CL and use that money to re tire the trailer with a 16" LT E Bridgestone R-238 commercial grade all steel ply carcass like the Sailuns if they fit or a ST E tire like the Provider....Endurance....Carlisle HD in that order. These are a better class ST tire than what we used 6-8 years ago.
Aug-21-2019 08:57 AM
WAY overkill on the tires. Bet it's placarded for D tires, so E tires would have been much more appropriate. I'd say run them at 70-80 and see how it rides. Sell the Sailuns and get some Endurance.
Lyle
OEM tires 235/80R16E
Shipping weight 9,870
Carrying cap 3,995
Hitch 1,865
One would be hard pressed to load 4K of "stuff" into it. So dry axle weight is 8K, throw a ton at it and axles are most likely under 10K.
This trailer would do better with Endurance ST235/80R16E's at 80 psi.
Chris
Aug-21-2019 08:53 AM
pyoung47 wrote:
I agree that the E rated tires would ride better. I was just tired of babying my tires and I actually did have a blowout with the original E tires, although they were past their "use by" date. Everyone seemed to recommend the Sailuns, and I do like having a tough tire, but they may be too tough. I may try running at lower pressure, since they do provide a chart for pressure/weight. The rig can gross around 14,000, and I'm probably approaching that at times when we are loaded for a craft show. Thanks to all for the thoughts.
Aug-21-2019 05:15 AM
Aug-21-2019 03:15 AM
Aug-21-2019 12:31 AM
Aug-20-2019 09:36 PM
Lyle
Aug-20-2019 08:28 PM
Aug-20-2019 05:41 PM
