โDec-16-2019 05:48 AM
โDec-31-2019 07:29 PM
โDec-31-2019 06:49 PM
Me Again wrote:
Turning the handle when closed is not locking it. The act of turning the handle is to prop it open for coupling, when you back into it correctly it contacts a mechanism that releases it to slide closed under spring tension. If the flange of the king pin does not interfere with the latch mechanism the handle will pop all the way in under spring tension. Putting a pin or padlock in it when in is locking it. I never saw it all the way in, in the early video's.
โDec-31-2019 04:00 PM
โDec-31-2019 01:14 PM
Me Again wrote:RCMAN46 wrote:
But in this case the OP did not close the hitch plain and simple.
I am not sure that is a correct statement. When connected correctly the lever will go in all the way by it's self(it is spring loaded to be in). That is why when pulled out you turn it down to keep it open in preparation for coupling up.
My Hi-Jacker worked in a similar way.
If the King Pin is high then the head does not latch properly and the handle is still out part way, as it cannot pop into to the latched position. The lower larger area of the King Pin is interfering with the latch mechanism, which is one of the forms of high hitched. Chris
โDec-31-2019 12:30 PM
RCMAN46 wrote:
"Lets do this, yes it was high hitched , if thats what it will take, but in the classic sense , no it was not high hitched, but lets use that . My point was there was no gap ."
Lets assume for argument that we have 4 extra slip discs. That will not allow the subject hitch or any hitch to latch. There will still not be a gap. I would call that a high hitch even though the pin is not on top of the jaws.
It would not matter what hitch is used including the B&W it would result in a dropped trailer. Now it will be said that that can not happen with a B&W as the arm would be open. But if you look at this picture it is clear the subject arm was also in the locked open position.
In this picture I believe you can see the pin just to the left of the jaw. You should not be able to see the pin when the hitch is closed and latched.
There was nothing wrong with the hitch is was an operator error.
โDec-31-2019 11:05 AM
โDec-31-2019 10:32 AM
โDec-31-2019 09:09 AM
โDec-31-2019 07:56 AM
Me Again wrote:cummins2014 wrote:
Snip...
Their is one fact here, he put a bind on the handle closing. The handle would not close, he pulled out ,and dropped the fifth wheel . I will repeat, saw it first hand in Montana two summers ago in a small RV park , same thing, except he realized his handle was not closing. The disk plate was banged up a little ,and was warped , holding it up just enough to put a bind on the handle. Took the disc off ,all was good. Handle closed ,and off he went.
I glad the you acknowledge that to many slip discs can cause a high hitch condition.
What we do not know is the full sequence, as the video is highly edited. RCMAN46's one photo shows what appears to be a sliding bar behind the king pin at some point in the sequence.
Update: Part #3 is now available. Extra slip disc seemed to be causing the problem of not latching correctly, cause a higher than normal hitch up and create the uncoupling problems, when he finally got it hitched.
https://www.youtube.com/watch?v=MHsVk46MR_M&feature=youtu.be&fbclid=IwAR05m4NJHFSnmU0Ia2bpX0uYyieSzl...
You may have to back it up to the beginning.
Also, I can not find documentation on the older Husky 24K EZ Roller. However the latch handle does not have enough travel to be a true sliding bar hitch. Final concussion is that the extra slip disc caused it to be to high to latch correctly. Truly a case that a tug test would have exposed.
โDec-30-2019 08:22 PM
cummins2014 wrote:
Snip...
โDec-30-2019 06:43 PM
โDec-30-2019 01:10 PM
Cummins12V98 wrote:ford truck guy wrote:
WELL.....
I may as well add to this love fest...... I appreciate BOTH the cummins's posts... BOTH are very knowledgable, and not afraid to express their opinion..
Thus making it an interesting read most of the time :B
You gots dat right "MOST OF THE TIME" :B
Hey, late Merry Christmas!
โDec-30-2019 10:25 AM
cummins2014 wrote:
Do they still sell newspapers :B
โDec-30-2019 09:23 AM
bpounds wrote:It ain't so much the things that people don't know that makes trouble in this world, as it is the things that people know that ain't so. Mark TwainThe trouble with our...friends is not that they're ignorant; it's just that they know so much that isn't so. Ronald Reagan
I am always drawn first to the opinion page of a newspaper. I guess I enjoy reading stuff that I know just ain't true. Reminds me of this forum sometimes.
All in fun guys. :W
