seal pulling out?
boatmanea
I have a rubber seal pulling out from the corner of my fiver (2014 Jayco Eagle 34.5BHTS) at the inside "corner" edge where the overhead part that attaches to the pinbox comes down behind the tailgate. The ends are screwed in secure, so it hasn't slid or pulled in one direction, and trying to push it back in, it's tight! Almost like it's shrunk?!? Can't figure out how to add an image... sorry...
20 REPLIES 20
bpounds
I repaired mine and it has lasted for a while. Probably not forever. Exact same location as yours, around that bend. All I did was push the trim upward in its groove. A couple of inches I suppose. It has shrunk lengthwise over time. Then I ran a screw through the center of the trim right at the bottom so that it could not slip back downward. The screw is below the living quarters area, so no concerns about water intrusion down there.
2006 F250 Diesel
2011 Keystone Cougar 278RKSWE Fiver
boatmanea
Thanks for the help, all. Now, does anyone have a part number or exact name?
Lynnmor
When you replace, push back so as to gather more material rather than stretching it.
94-D2
Mine came out running down the highway in 100 degree weather. Fixed mine with flex seal adhesive. RTV silicone would work nicely too. Been good since.
2018 Ram 3500 Crew Cab Laramie 6.7L, Aisin, air ride, Ram puck prep, SuperGlide 20K auto slide.
2018 Bighorn Traveler 4 slide w/Apt.
Itโ€™s not what youโ€™ve done that commands respect, itโ€™s what you do.
Happy Campinโ€™
B_O__Plenty
TxGearhead wrote:
Yeah I've got one doing that. I haven't tried to fix it yet though. I'm thinking a heat gun and some silicone.
It shrunk. Nothing will work and look right except to replace it. Just did mine. Bought new off of Amazon for about 15 bucks for 100 feet, like I needed that much. I just cut it at the ends and inserted the new then used a small screw through the end to hold it in place.
B.O.
Former Ram/Cummins owner
2015 Silverado 3500 D/A DRW
Yup I'm a fanboy!
2016 Cedar Creek 36CKTS
laknox
Dave H M wrote:
Myself, I would call them trim strips or something.
Do they really "seal" anything?
In the boating world, they're called "rub rails", and do serve a purpose. My KZ lost the RR one completely when it got hot the first summer we had the rig. Just slid right down the track and onto the ground. Idiots at the factory didn't bother to secure the top. Dealer replaced it with a non-matching piece, but it doesn't slip out. I have the same issue, in the same place as the OP. Just need to buy a roll of it and DIY my own fix. Just one more example of a mfr cheaping out on stuff that a $5 difference would likely fix.
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
Dave_H_M
Curly2001
You can also use Proflex on the ends of them to keep them sealed and in place. I have both sides of mine do that and as said, it is cheap to buy new material and replace the old seals.
Curly
2019 Chev. Double cab 2500HD, 6.0, 4:10 diffs, six speed auto
2013 Heartland Sundance XLT 265RK
2112
This happened to me last year, on both sides. It started like in your photo but got worse.
I pulled it out, leaving it attached at the ends. Cleaned it, stretched it out and put it back in. Once I had a good fit, I put a few drops of superglue in the area where it started. So far so good.
2011 Ford F-150 EcoBoost SuperCab Max Tow, 2084# Payload, 11,300# Tow,
Timbrens
2013 KZ Durango 2857
azdryheat
I replaced mine. $20 for 50' of molding trim.
2013 Chevy 3500HD CC dually
2014 Voltage 3600 toy hauler
2019 RZR 1000XP TRE
cougar28
Replace it. Once they shrink they will never stay in place even if you did get back place. Itโ€™s not very expensive seal trim.
2002 F-250 SD CC 7.3PSD Auto. XLT Short Bed 4X4 Off-Rd.Pkg.Highland Green,Westin Sportsman Grille Guard (Black) RBW Li'l Rocker Slider ,Prodigy Control Towing Jayco Eagle HT 30.5 MLOK,Handy 5er tailgate
TxGearhead
2018 Ram 3500 CC LB DRW 4X4 Cummins Aisin Laramie Pearl White
2018 Landmark Oshkosh
2008 Bigfoot 25C9.4
2014 NauticStar 21 ShallowBay 150HP Yamaha
2016 GoDevil 18X44 35HP Surface Drive
boatmanea
BOOM!
Thank you, BarneyS!!!
jaycocamprs
boatmanea wrote:
I just can not for the life of me figure out how to put a dang picture on here... Its shrunken, for sure, just didn't know if that was "normal" versus a sign of a bigger problem.
Normal, I've had to replace on both sides. It's just a cover to hide the screws.
2018 Silverado 3500 DRW
2011 Montana Mountaineer 285RLD
