Seeking Clever ways to carry sewer hose
cruz-in
Hi Team,
It seems, for one reason or another, all the tried, true, and easy ways to carry the sewer hose will not work on our new RV (no bumper, hard to find places to secure pvc to carry, fuel tanks in way, generator exhaust in way, etc...)
So does anyone have any clever ways they carry the sewer hoses?
Thanks
Dan
2011 Monaco Vesta
Interesting Coach
This particular one was the prototype.
37 REPLIES 37
Chiefcpo
Goducks10 and 2do have the same as I do. Farm supply to get 5" fence post 20 bucks appox, Lowe/Home depot for the end caps $6.00, 2 8" nails, and a scrap of metal (mine were free as I do HVAC) 1" x 24" need 2. 4 self tapping (drill point) screws. You will have less than 40 bucks. Give me a PM and will talk more with you and give you my cell number (that way I can send you pic's of step x step way. Had to drop cleanout side by 3" to clear siding on RV.
Nutinelse2do
goducks10 wrote:
Mount a 5" PVC fence post under the frame.
X2, except ours is white to match our coach.
Living Our Dream
MTHRSHP - 2006 KSDP 3912
Cummins 350ISL...Spartan Chassis
ESC POD - 2019 Ford Ranger XLT FX4
Zippy Scoot- 2018 Honda PCX 150 on an Overbilt Lift
Shredder at the Rainbow Bridge - You Will Always Be With Us
ependydad
I didn't read any of the prior posts- but my first thoughts are a rubbermaid tote in the basement storage; with a lid, there is no odor.
Second is to use the PVC fence post mod, but just keep them in the truck bed. If you cut them to the bed's length, they wedge in nicely (though I still threw bungees over top to keep them from lifting any way).
2017 Spartan 1245 by Prime Time
2018 Ram 3500 Crew Cab DRW w/ 4.10 gears and 8' bed
FW Hitch: TrailerSaver TS3
Learn to RV- learn about RVing - Towing Planner Calculators - Family Fulltiming FB page
laknox
cruz-in wrote:
Hi Team,
Thanks
Dan
Dan, take your hose and hook it to itself, then coil it in a shallow plastic tote, like the short ones you use for under-bed (in your house) storage.
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
Lantley
cruz-in wrote:
Hi Lantley,
How did you mount the PVC to the I Beam?
Thanks
Dan
Self tapping bolts and a 6" galvanized pipe bracket.
Install was amazingly simple.
6" PVC can be pricey,however you can use 6" fitting to create a simple screw on cap. No need to create a door or lock cap from miscellaneous parts.
yellowdog00
X2 on the Ziplock Big Bags size XXL.
2016 Jayco North Point 301RETS, Pullrite SuperGlide
2015 Ram 3500 SRW CC 6.4 Hemi 4.10
time2roll
There must a way to mount the tube or fence post under the RV.
Post a pic of the underbelly and charge up your drill.
Oldme
Mine has no bumper either.
Many have a molded in "bumper".
I have a open bay w/door that is over the
tanks. I found a small plastic crate that fits
and after I rinse the hose it collapses in a
circle and fits inside. I have a bungee cord
over it to make sure it stays.
cruz-in
Hi Lantley,
Thanks
Dan
2011 Monaco Vesta
Interesting Coach
Lantley
I have 3-6" PVC pipes attached to my underside. They contain sewer hoses and fishing rods.
The PVC pipe can be mounted parallel or perpendicular to the beam
dmeck
If you have a ladder could you mount something to it?
Houston_Remodel
How is this for an idea ?
Get one of them 5" fence posts and mount as directed. Get another 5" fence post and cut it lengthwise at opposing corners. Slide the new L piece inside before the hose (or during) and use the L piece as a support for the hose when in use .
McGuyver moment waning.
2015 Starcraft Launch 24RLS
2014 Ram 2500 diesel 4x4
Guarded by 2 Jack Russells
SH
Underneath the front bulkhead in a PVC pipe.
2001 Alpenlite 35RK
2007.5 Chev LMM Duramax/Allison
BD Variable Vane Turbo Brake
TST 507
2010 FLHTC Electra Glide Classic Red Hot Sunglo ๐Ÿ™‚
Pangaea_Ron
I used 6" diameter corrugated black plastic drain pipe, and attached it to the under frame of my MH with SS pipe clamps. The pipe itself is flexible and can fit around and conform to the MH framing. Rather than end fittings, I drilled holes at each end and dropped carriage bolts into the holes to keep the sewer pipe and fittings inside. Another advantage of the drain pipe is that it has drain holes to allow the sewer hose to dry.
2008 Itasca SunCruiser 35L
2014 Honda AWD CR-V EX-L
Dick_B
X2 on the plastic tub
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
