Nov-06-2017 09:39 AM
Nov-09-2017 11:44 AM
laknox wrote:
You can get TWO of these from Harbor Freight for less than the cost of ONE Honda 3000:
https://www.harborfreight.com/3500-watt-super-quiet-inverter-generator-63584.html.
Lyle
Nov-09-2017 09:52 AM
2oldman wrote:
You're claiming an open-frame generator "isn't much louder" than 2 Yamahas? Perhaps you've never done a sound comparison from 300' away.
Nov-09-2017 07:50 AM
2oldman wrote:X2 It's always the guy with the loud generator that thinks his is nearly as quiet as everyone elses.waltbennett wrote:You're claiming an open-frame generator "isn't much louder" than 2 Yamahas? Perhaps you've never done a sound comparison from 300' away.
We've had one of their 4kw peak regular ones (a whopping $300!) for four years and it's worked flawlessly (and isn't much louder than the two Yamaha's I had previously).
Nov-09-2017 07:08 AM
Nov-09-2017 06:36 AM
Nov-09-2017 06:08 AM
Nov-09-2017 04:49 AM
Nov-08-2017 11:40 AM
Butch50 wrote:
I already have a Honda 2000i and a Yamaha 3000iSEB with remote start. I really don't want to carry either of them in the bed of my truck so I think I have found the way to carry the Yamaha without being in the bed or hanging off the back of the 5er. Torklift Lock and Load rack. This will allow me to carry the Yamaha on the front of the truck with a front hitch to install the Lock and Load on it. I have plenty of capacity on my front axle to carry it and I have used front racks on my other trucks with a truck camper and never had a heating problem.
It also makes it easier to take off the truck when I'm not using it and it is built to handle generators and locking them on.
Here is what I'm talking about:
Torklift Lock & Load
The worst part of this is that a few years back Torklift ran a contest on NATCOA and I won one of these but at that time I had just switched to a MH so contacted them and told them that I no longer had a need for one and to please pass it along to someone else. Now years later I'm looking at buying one. Crying shame that I didn't just take it and stow it away.
Nov-08-2017 08:36 AM
Nov-08-2017 07:01 AM
Nov-08-2017 02:46 AM
Nov-07-2017 09:02 PM
bpounds wrote:
I have the 2k Honda. Only the one, so we don't run A/C. I like it okay. Resale value on those ie2000 is great. You can own and use one for years for about $100.
One thing I don't see mentioned too often, is the issue of noise and distance. It is nice to move the little gen away from the trailer where we are trying to watch TV or sleep. For that reason I would not like a unit mounted on the pinbox, right outside the bedroom wall. Even hanging on the bumper will result in more noise in the coach, than the same genset would sitting on the ground.
Just something else to think about. Different folks will reach different choices.
Nov-07-2017 10:41 AM
rjxj wrote:
The easiest way to use a genny is to bolt/secure a remote start model in the truck bed. Install a transfer switch in the rig and wire in number 10 gauge rubber coated cable between the transfer switch and up to the generator. I fastened mine under the overhang and up past the pin box. Make it long enough so you can pull the truck hood to pin so the noise is away from the rig.
You can sit inside and fire it up or start it on the road for taking breaks or cooling down before you set up. You do have to disconnect to drive away but I'd never ride off with ac or something running and I wouldn't ride away with the generator sitting there. Easy to fuel it while at a gas station.
I had modified and mounted a Champion on the rear bumper of a TT but isolating it from the RV is much quieter. When it's pointed away from the FW we forget that it's running when eco is on.
Nov-07-2017 10:20 AM
Nov-07-2017 09:36 AM
