Sub-freezing Traveling
Tony_B
If you are traveling in sub-freezing weather:
1). Will the furnace work while on the road?
2). Do you run the furnace while going down the road?
Thanks in advance
Tony B
8 REPLIES 8
larryn
bring your indoor/outdoor cordless thermometer from home to monitor the temp in your trailer works great.We run our heater some years until we get south of K.C Mo(8 hours+).Make sure you have a charging wire to your unit. dont ask me how I know.
Tony_B
Thanks guys. You have been a great help.
My vents will not be covered when the slides are in. In the living room, theer is no way it could be covered.
In the Bedroom, the sheets/blankets could possibly slip and cover a vent. I will make sure that they cant.
Thanks again.
Tony B
Old-Biscuit
Furnace needs propane and 12V DC to function
Furnace needs minimum recommended airflow to & from furnace or it will overheat tripping the High Temp Limit Switch .....then furnace will cool down/refire/overheat ---trip until temp reaches t-stat set point.
So IF furnace 'return' and/OR Too Many discharge registers are blocked it 'limit cycle' Burner On/Off
SO answer is 'Depends' on your trailer layout.
Try it BEFORE you need to have it and see how it functions.
Lwiddis
Yes, no
GordonThree
Watch out for ice while traveling "sub freezing"
Ice will gather on the sewer, axle, suspension, TV antenna, roof vent, etc. It really adds up to extra weight fairly quickly. When pieces break free at highway speed there will likely be damage.
2013 KZ Sportsmen Classic 200, 20 ft TT
2020 RAM 1500, 5.7 4x4, 8 speed
memtb
We travel a bit in cold (sometimes below zero) temperatures, with water in the unit, so yes....the heater is on. And as previously stated, be sure to have at least some of your vents open to flow!
Todd & Marianne
Miniature Schnauzer's - Sundai, Nellie & Maggie Mae
2007 Dodge Ram 3500, 6.7 Cummins, 6 speed manual, 3.73 ratio, 4x4
2004 Teton Grand Freedom, 39'
2007 Bigfoot 30MH26Sl
Campinfan
You have to make sure the vents in the floor aren't covered by the slideouts. Mine are but I never really needed to turn the furnace on. Last year we went to Florida in the winter and stopped in Savannah, GA for the night. We turned the heat on then. On the way home, we stopped for the night near Atlanta and blew out the lines in the morning before we left.
______________________
2016 F 350 FX4 4WD,Lariat, 6.7 Diesel
41' 2018 Sandpiper 369 SAQB
Lovely wife and three children
K_Charles
Yes
Sometimes
