Sulfur smell
buc1980
How can I get ready of the smelly sulf from my water
2017 Ford F350 DRW,2005 Kountry Star 35ft,16750 lb weight on SAILUN tire,6 points LIPPERD Level-up.New Mor/ryde IS suspension install.Full body paint 2022.RV flex roof 2023
9 REPLIES 9
Old-Biscuit
Three basic types of anode rods.....
Aluminum
Magnesium
Zinc
Aluminum lasts longer, doesn't attract bacteria BUT can collect deposits that make removal difficult
Magnesium provides stronger 'current' attraction so they don't last as long and can attract bacteria that produces sulfur smell
Zinc......commercial use. Very effective but very short life span
Some aluminum/zinc mixture rods available but hard to find.
Routine draining/flushing of water heater tank helps.
Changing from magnesium to aluminum will help
Vinegar soak will clean up inside of tank/system
All depends on make up of source water.
Don't forget.......
Sulfur smells can also be battery overcharging
skipnchar
Sounds like you have sulfated water which is caused by sulfur in the water SOURCE. This is sometimes also referred to as "onion water". If you always fill from a municipal water system that does not contain a lot of sulfur you SHOULD not get Sulfated water. If you DO end up with the problem, all it takes is to drain, flush and sanitize your water system to get rid of it. Of course after sanitizing you'd still need some more flushing to get rid of the bleach odor and taste.
It doesn't have anything to do with anode rod or length of time the water is left in the system, it's in the water SOURCE and builds up over time.
2011 F-150 HD Ecoboost 3.5 V6. 2550 payload, 17,100 GCVWR -
2004 F-150 HD (Traded after 80,000 towing miles)
2007 Rockwood 8314SS 34' travel trailer
US Govt survey shows three out of four people make up 75% of the total population
3_dog_nights
there's another thread open on this under "general" also a number of them in history. Lot's of ideas and advise to follow.
Bob & Lynn
2 Chihuahua's, Ella, Gracie
was-2013 Open Range 424RLS,06' Chevy 3500, dually, Duramax/Allison
also was - 2015 Winnebago Adventurer 37F, towing 2003 Jeep Wrangler
now - 2021 NoBo 19.5, 2019 Honda Ridgeline RTL (Talk about downsizing!)
routeforty
Had that problem in a Jayco park model a couple years ago. Drained the HW heater and refilled it with a cup of bleach added. Let it set for a few hours. Repeated it. End of problem. Was a brand new heater from Lowes(20 gal) The owners manual said it was a chemical reaction with the anode, and there were 2 types of anodes(magnesium & don't remember what the second one was) If I replaced what came with it with the other type it would eliminate the problem-but no one knew what kind was shipped with the heater. Hence the bleach. Gary
2018 coachmen leprechaun class c 2008 KZ spree 260FL
joegray
Buy a new fresh water hose. Don't fill your tank with a garden type hose, use only one for potable water. Flush your holding tank with a little bit of bleach. I had a sulfer smell and doing this got rid of it.
n7bsn
IMO, there are two common sources of the sulfur smell, neither is the "electrode" (which doesn't exist...I think the poster meant sacrificial anode)
The most commons source is you left water in your tank for an extended amount of time, this water had both aerobic and anaerobic bacteria. If water is left for an extended time, undisturbed. All of the O2 is used up and the anaerobic bacteria can then start working, as they live/grow they release SO2 (sulfur-dioxide).
The other is less common, but happens most often in areas like Texas. There is natural SO2 in the water and you are smelling this.
The solution to either is flush the tank. I would also clean the tank with a small amount of Chlorine bleach to reduce the amount of bacteria in the tank
link
another link
2008 F350SD V10 with an 2012 Arctic Fox 29-5E
When someone tells you to buy the same rig they own, listen, they might be right. When they tell you to buy a different rig then they own, really pay attention, they probably know something you don't.
larry_barnhart
I ran vinegar though our water system and let it soak for a few days and then rinsed it out including the water heater. Just because we winter in Arizona not because of smell. I did help a couple clean out their water heater for the sulfur smell and it fixed the problem.
chevman
chevman
2019 rockwood 34 ft fifth wheel sold
2005 3500 2wd duramax CC dually
prodigy
KSH 55 inbed fuel tank
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
FMCA # F479110
sem1
And rinse out tank
WyoTraveler
From your hot water heater? Electrode inside heater gves off that odor. Replace it.
