TIRE TIRES TIRES
352
Does anyone have any information from the tire manufacturer why we should use trailer tires instead of truck tires on trailers? If all the side wall ply and tread ply are the same, what is the difference?
The manatees of Halls river Homosassa Springs Fl
1985 Chevy Silverado c10. 454 stroker / 495 CI = 675 HP. 650lb of torque. Turb0 400 tranny. 3000 stall converter. Aluminum heads. 3 inch exhaust flowmasters. 2 inch headers. Heat and air. Tubed.
41 REPLIES 41
time2roll
Old-Biscuit wrote:
kydale wrote:
http://www.tirerack.com/tires/tiretech/techpage.jsp?techid=219
Enjoy
Who would use 'P' rated tire on a trailer :H
I might on a single axle. Derate 10%
joeburnes
mileshuff wrote:
Big issue for me is that there are no major well known tire companies making ST tires except Goodyear with their Marathon. Goodyear moved production of that tire to China and the quality went down. Most ST tires are made in China by manufactures few would recognize. The only ST thats often recommended here would be Maxxis. A 2nd possibly might be Carlisle. They have a long history of having a horribly bad tire. However, they came out with a newer design about 3 years ago that many say is decent. In otherwords, my issue isn't ST vs LT. Its manufacture and consumer experiences for me.
I admittedly don't know much about this topic other than to say that if you have the money and have chosen a manufacturer, go with the highest weight rating you can afford. Reason is they will run cooler and there will be less stress on them, thus reducing the chance of a blowout.
As for Carlisle, I never knew them until I bought a cargo mate trailer that had them on it in 2008. I obviously didn't know what I was doing when I ended up pulling 15,000 lbs with my 1/2 ton from MO to TX. When you pretty much have to tap the brakes to be able to steer, you know you need to start reading stuff. lol My axles were 3,750 and the tires are rated about 2,000 each (I think). I had no issues. Now, the trailer has made a few trips since, but mostly sat in the same spot for years. I had to move it recently and it was obvious the tires were dry rotting. My tire guy said he wouldn't risk it. I bought a spare just in case and took the trailer 200 miles with no issues. A year later (2015), I did that 200 mile trip again. I blew a tire within 5 miles of home because of a construction area that was rougher than a washboarded dirt road. The tire lost its tread, but held together. It was the rear of 2 axles and caused NO damage to the trailer. I know who I'll buy tires from when I have to move the trailer again or when my 5th wheel needs new ones.
Also, I've heard of people filling their tires with Nitrogen as it stays cooler under high heat conditions.
Remember: If you light a man a fire, he's warm for one night....but, if you light a man ON fire, he's warm for the rest of his life!
ol_Bombero-JC
donn0128 wrote:
I take it you have not searched the forums yet? Your question will turn into a he said, he said argument real quick.
Hmmmmmm - the OP ("352") has been on the forums since 2004
Either he has been living in a cave in Tibet - with no access to the internet or other social media.......
Or -
he's stirring the pot.
OP - *if* you fall into the first category - the answer (as already noted) is spelled S-E-A-R-C-H....as in SEARCH, SEARCH, SEARCH...:R
The thread title (subject) you chose, would be a good 'keyword' for same (the search). NO need to enter it 3 times or in CAPS...;)
Of course, you could PM "4X4Dodger" (Fast Eagle's kin - or a GY tire dealer) and he will happily detail the merits of ST tires!...:W
mileshuff
Simply put, there just aren't very many top brand ST tires made but there are a ton of junk China brand ST's. There are quite a few LT's that many here have had great luck with. Michelin does list their XPS Rib LT's as being suitable for RV's. I have about 15,000 miles on mine so far and doing great.
2014 Winnebago 26FWRKS 5th Wheel
2007.5 Dodge 2500 6.7L Diesel
2004 Dodge Durango Hemi 3.55 (Used to tow TT)
Old-Biscuit
Enjoy
kydale
Enjoy
Old-Biscuit
I use LT tires on my truck and trailers.......
ADAD437
trailer tires are supposed to give a softer ride but as mentioned they blow quicker. personaly i use truck tires on my A and it handles good enough for me.
James,Gail & Pancho
2005 georgie boy Pursuit
๐Ÿ˜›
JIMNLIN
ST tire makers/dealers says we should use ST tires and not P or LT.
P and LT tire makers/dealers tell us we can use thier P or the LT if the tire meets the load capacity.
Its simply that simple :R.
Difference ?? Having made a living using both I've found much higher quality and long term service from a quality LT tire.
downtheroad
FACT: Use the round rubber ones...
The rest of the thread will be opinions and probably turn nasty.
Arctic Fox 25Y
GMC Duramax
Blue Ox SwayPro
Allworth
Enter "tires" in the search field and read for the next year.
Simple answer: Trailer tires (ST) "seem" to blow out more often than light truck (LT) tires.
Using ALL CAPS is considered yelling. Not polite.
Formerly posting as "littleblackdog"
Martha, Allen, & Blackjack
2006 Chevy 3500 D/A LB SRW, RVND 7710
Previously: 2008 Titanium 30E35SA. Currently no trailer due to age & mobility problems. Very sad!
"Real Jeeps have round headlights"
donn0128
