Apr-30-2013 06:51 AM
May-01-2013 02:15 PM
May-01-2013 07:29 AM
Apr-30-2013 08:35 PM
Apr-30-2013 07:54 PM
Me Again wrote:Cummins12V98 wrote:Me Again wrote:
The best option is to have a good welding shop add a subframe between the spring hangers and the trailers frame. Square or rectangular tubing. While they are at it , it does not hurt to have tubes run side to side at the three spring hanger locations. The picture below is after a frame repair. It shows old subframe and new cross tubes and gussets at the hangers. Print it off and take it to the welding shop with you.
Chris
Did you do the work or did Smiley's?
Looks just like the job a friend of mine and I did on our last 5er.
Those are Smiley's welding beads!!!!! They are not cheap, however they do quality work!!!
They flipped the axles about 6 years ago and fixed the I-beam cracks a few years ago.
Nice people to deal with. I was two weeks from leaving for Arizona and they got me in to fix the I-beam cracks.
I contacted both Lippert and Cardinal, and one of them helped me with the bill!
Chris
Apr-30-2013 07:40 PM
Chris
Apr-30-2013 04:01 PM
Apr-30-2013 03:23 PM
Apr-30-2013 01:20 PM
ol Bombero-JC wrote:Huckleby wrote:
The other thing I need to consider is cost. It is a 1992 and I can't see putting much into it. Is it that vital that I correct this nose up attitude?
The rig photo in my profile shows the level (or lack of level) better.
The best method may not be the best in your situation.
(at least monetarily $$)
The blocks may be a less expensive and viable solution, worth a try.
Try a combo of short blocks and taller tires - move up a wheel size?
Replacement steel wheels aren't that expensive.
Internet size comparison sites will give you the dimensions of tires - what you have vs the possibilities - enter sizes, results in inches.
Don't forget to consider an increase in size reduces the distance *between* the two tires on the same side.
Some trailer mfgrs used steel (factory) pickup truck wheels - if you're trying to further cut expenses - check the bolt pattern & rim width - then visit a salvage yard.
Apr-30-2013 11:50 AM
Apr-30-2013 10:53 AM
Apr-30-2013 10:06 AM
Apr-30-2013 10:03 AM
Apr-30-2013 08:39 AM
Chris
Apr-30-2013 07:12 AM
