Toilet water problem ???
ilvtravln
We have an 09 Bighorn with a Sealand toilet model # 110. When I step on the pedal to flush the toilet the water in the bowl spits upward. The water pressure regulator is attached as it is suppose to be. Black tank was empty. Any ideas? Thanks
Art
4 REPLIES 4
ilvtravln
jjotmo wrote:
Is it all the time or just when you first hook up? Some air will be in the lines when you first hook up to a water source so I run my bathroom sink first to minimize the spray.
This happens all the time. I always bleed the air out of the lines first. Thanks
Art
Sea_Six
As far as toilet water is concerned, I recommend Drakkar Noir for the men and Modern Muse by Estée Lauder for the ladies.
Old-Biscuit
Water has to displace air when you flush toilet.
Normally that air would go up vent line
Check the vent line for:
Pluggage or if it has slipped down into tank
You can remove vent cap and run water from garden hose down it into tank
And you can see if vent line is no longer flush with roof
jjotmo
