Tow Vehicle Question (year recommendations)
Aridon
Folks, could use some advice from people with more knowledge on the topic of tow vehicles than I have.
I know the DRW 1 tons in the relatively recent past have been upgraded considerably. If I were considering a used truck to tow a:
Grand Design Momentum 395
Momentum 395 Stats
Dry weight: 15,400
Hitch weight: 3,400 ish
GVW: 25,000
What years would I be looking at to be able to tow that with a DRW 1 ton from Dodge or Ford or Chevy?
Anything I should know about those years in particular (years to avoid, specific issues with components, new year for engine type etc)?
Thank you for time and knowledge.
2019 Grand Design Momentum 395
2018 Ram 3500 DRW 4.10
2014.5 DRV Atlanta (sold)
2008 Newmar 4330 (Modified) Sold
19 REPLIES 19
john_bet
jerem0621 wrote:
Do you have to have a CDL to be GCVW OVER 26k?
Thanks!
Jeremiah
No Fedaral CDL of any class needed for any RV period. All RV's are exempt.
2018 Ram 3500 SRW CC LB 6.7L Cummins Auto 3.42 gears
2018 Grand Design 337RLS
RustyJC
Thanks!
Jeremiah
You're not engaged in commerce, so why would a CDL be required?
Texas requires an exempt (non-commercial) Class A license for GCWRs of 26,001 and higher if the towed load is over 10,000 lbs.
Rusty
2014.5 DRV Mobile Suites 38RSSA #6972
2016 Ram 3500 Dually Longhorn Crew Cab Long Bed, 4x4, 385/900 Cummins, Aisin AS69RC, 4.10, 39K+ GCWR, 30K+ trailer tow rating, 14K GVWR
B&W RVK3600
Cummins12V98
work2much wrote:
RustyJC wrote:
Our 2016 Ram 3500 dually CCLB 4x4 Longhorn with 385/900 Cummins, Aisin AS69RC transmission and 4.10 axle ratios is rated for 39,100 GCWR and 30,050 trailer tow rating.
Rusty
Shopping for this truck now in 2017 version same motor/trans/axle ratio. I take it you are happy?
I would highly advise adding the factory rear air option. I have same truck in the 15 version. Pulls my 33K combo with confidence is all weather and terrain conditions.
I am sure Rusty will add his positive comments. Rusty has more power. 😞
Pic is with 9,750# @ full RAWR. Unloaded pic is in ALT ride mode same with loaded pic. Notice the same ride height automatically is kept.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
RustyJC
work2much wrote:
Rusty
I'm very pleased with the truck. I have about 8,500 miles on it with most of those towing - no problems at all. The only major modification I've made is to have the dealer install a 55 gallon Titan OEM replacement fuel tank for extended towing range. I had the dealer do the installation for warranty coverage reasons.
Rusty
B&W RVK3600
work2much
Rusty
2022 Ram 3500 Laramie CTD DRW Crew 4x4 Aisin 4:10 Air ride.
2020 Grand Design Solitude 2930RL 2520 watts solar. 600ah lithium. Magnum 4000 watt inverter.
stickdog
Thanks!
Jeremiah
As others have stated it depends what state your licensed in and 26,000 is not the trigger that requires a non commercial cdl. In many states towing over 10,000 lbs. requires it.
9-11 WE WILL NEVER FORGET!
FULLTIME SINCE 2010
17 DRV MS 36rssb3
17 F350 King Ranch CC DRW 4x4 6.7 4:10 B&W hitch
John
“A good traveler has no fixed plans, and is not intent on arriving.” Lao Tzu
Cummins12V98
Thanks!
Jeremiah
Not in WA, SD where I am familiar with. CA requires a endorsement from what i have been told.
I am licensed in SD and can tow my 33K combined anywhere with no special endorsement.
Aridon
Thanks!
Jeremiah
No, not necessary in our state.
jerem0621
Thanks!
Jeremiah
TV-2022 Silverado 2WD
TT - Zinger 270BH
WD Hitch- HaulMaster 1,000 lb Round Bar
Dual Friction bar sway control
It’s Kind of Fun to do the Impossible
~Walt Disney~
RustyJC
Rusty
B&W RVK3600
justafordguy
2011 and up 6.7 Ford, also the exhaust brake got much better in 2015.
2015 Heartland Gateway 3650BH
2017 F350 CCLB KR FX4
2005 F250 CC FX4
77 Bronco, 302,C4,PS,PB,A/C,33" KM2s,D44/Lock-Right,9"/Grizzly locker
Aridon
Thanks folks, I don't know how I screwed up the GVW on the fifth but it being 20k instead of 25k makes a huge difference in what can and can't tow it.
Appreciate the help.
kennethwooster
If you go dually they should all handle the job. I'm only acquainted with Ford. Having owned a 6.0 6.4 and now 6.7 I definitely would only get the6.7 which is 2011 up. I have a 2014 6.7 and DRW. I love the current truck. It will handle your rig.
kenneth wooster- retired farmer. Biblical History Teacher in public HS, and substitute teacher.
wife Diana-adult probation officer, now retired.
31KSLS Full Body paint Cameo
Ford F350 2014 DRW 4X4 King Ranch.
20K B&W Puck mount hitch
Cummins12V98
2013 or newer RAM/Cummins/Aisin/4.10's. True Medium Duty combo. 2015 or newer with factory Rear Air Ride is a GREAT option. I have that combo.
I tow 33K combined, the truck has performed great in all weather and mountain conditions. Trans temp 165-172 no matter the conditions. Cooling easily in check even on 14 percent grades.
9,750# on the 4 rear tires, truck rides level with the factory rear air.
