Towing capacity
nomoney
I have a 1999 Ford F350, dually, 7.3 w/410 rear in (6 speed manual); I am looking at buying a Grand Design/ Reflections, model 303RLS. The GVWR (lbs) is 11,995; UVW (lbs) is 9245; hitch weight is 1687. I have tried to find information on the towing capacity for my truck, but no luck so far. Should I be able to tow this 5th wheel with my current truck? Your thoughts on this are appreciated!
10 REPLIES 10
nomoney
Thanks so much everyone for all of the replies. We are seriously considering getting the Grand Design Reflections, and your opinions have been helpful!
Shepherd
Your fine,enjoy the new rig.:C
2018 Ram 3500 CC aisin/4.10
2014 Rushmore Monticello
Don_Z
I have a 2000 F350 dually crewcab 4x4 with 4.10 gears and the automatic 4 speed transmission. My truck full of fuel, with the hitch in the bed and me behind the wheel tips the scale at 8185 pounds. The GVWR for the truck is 11,200 pounds, CGVWR is 20,000 pounds.
If your truck is a regular cab or extended cab, the weight of your truck will be a little lower than my truck's weight.
With just me in the truck, I can handle up to 3,015 pounds of pin weight and a max trailer weight of 11,815 before I am at the the specified limits of the truck. I hope this helps.
Don Z.
2000 F350 Crew Cab Dually 7.3 PSD,Banks Stinger Plus,Line-X Liner,Prodigy Controller,Reese Signature Series 18K hitch
rhagfo
I would say you are good to go! May be close on the GCVWR, but with the 4.10's should not really be an issue.
My 5er has a GVWR of 12,360# and a dry of 9,820# gross about 11,000#. I am over GVWR on my TV, but well within axle and tire ratings. I have no issues with a GCVW of 19,000#+.
You got to love those single digit tow charts!!
mdamerell
PDF Ford 1999 Tow Guide
Truck probably weights about 8,000# loaded (my 2004 weights 8,200# ready to camp.)
Trailer GVWR 12,000#
Truck GCVWR is 20,000# and you are there.
20% average pin weight of 12,000# trailer is 2,400# pin and you should be able to carry that.
2012 Sundance 3100RB w/Reese Goose Box
2004 Ford F350 6.0 L PSD, CC, DRW, long bed, B&W drop ball hitch, Firestone Ride-rite air bags.
ScottG
Trucks back then didn't have nearly the capacity of todays trucks so your going to be very close to maxing it out.
It wont be much fun but it will do it.
newk
Google it. I did and got lots of hits. Here was just one:
clicky
(You shouldn't have any problem.)
Mike_LeClair
IMNSHO, you are good to go. Your F350 should be more than capable. Make sure she is well tuned up and that allof the running gear components are in tip top working condition.
Cheers!
Mike
Something Old, Something New
2012 F350 SRW, 6.7l Powerstroke, 3.55's front and rear.
2008 Fleetwood Regal 325RKTS
Mike, Carol and our 4 legged "furry child" Kenzie Shweenie Tod
old_guy
have you checked trailer life magazine. go to their web site and locate the tow rating section and see if your truck is listed.
KD4UPL
I have no idea what the towing capacity of that truck is. However, my thoughts, I'm quite certain it's capable of towing that trailer.
