โMar-16-2021 07:45 PM
โMar-22-2021 12:13 PM
Cummins12V98 wrote:
"I am now looking at a new Dodge with a short box."
No such thing, Officially RAM since 2013.
โMar-21-2021 08:04 AM
โMar-21-2021 07:59 AM
โMar-20-2021 05:28 PM
โMar-20-2021 01:28 PM
โMar-20-2021 08:49 AM
โMar-20-2021 08:32 AM
CaLBaR wrote:
I really am not sure never having a 5th wheel before what the pre-occupation is with being able to turn 90 degrees. I can't even get close and have never had to with any of my TTs and have never had an issue maneuvering anywhere. I do understand that you can damage the truck and trailer if you turn too sharp but just don't see the need for it.
Not sure what I am missing with this. Sorry if I stole the OPS thread.
โMar-20-2021 06:33 AM
โMar-19-2021 08:51 PM
cummins2014 wrote:GPG52 wrote:
I also experienced the same issue as LADYRVer with the slide binding the tailgate.
(2006 Dodge MegaCab with 6'4" box, 2008 KZ Dorango, 1/2ton)
Solution was installing a Reese Sidewinder, worked like a charm.
Another good solution is the Andersen hitch .
โMar-18-2021 08:14 PM
philh wrote:
Once you look at loaded pin wt, you're probably in dually territory
SPECIFICATIONS
Hitch Weight:2220 lb.
GVWR:18000 lb.
UVW 13064 lb.
CCC 4936 lb.
โMar-18-2021 06:56 PM
โMar-18-2021 06:32 PM
โMar-18-2021 06:31 PM
โMar-18-2021 06:30 PM
